Just Another CB450
anderson
Hello All,
I've been looking over the forums, contemplating posting for a while. I finally got around to it, and am looking forward to input from you all as I go along.
To start, I have a '72 CB450K5 with about 6k on the odometer. All of the pieces are there, they've just been sitting in a barn since 1984.
The PO put ape hangers, a highway bar, and a sissy bar on it. They also cut the ends off of the mufflers, cleaned them out, and then proceeded to stuff and weld lawn mower mufflers inside the stockers.
So in reality I have rust, oxidation, and a lot of work to do. We did take the ape hangers, highway bar, and sissy bar off. And we polished one cover on the engine before I was warned of a mutiny at home.
My plans are to break it down, clean it, tune it and put it all back to together with some upgrades along the way. I have a donor vf500 that will provide a a 'new' front setup (except the headlight and guages). We are also going to use the rearsets from the VF and rear tire/brakes as well.
I'm looking for a cafe seat (or maybe the foam and cover to work with the stock seat pan), oh and maybe some upswept Dunstall megaphones and a 2-into-1 header.
Pics will come as I get them, thanks in advance for any input.
Theres a lot of potential there! I love my CB450. I think its just enough power, and it handles pretty well too once you get the suspension sorted.
I spoke to the guys at team hansen honda when i was thinking of doing exhaust work, and they say that a 2-1 is no good on the 450...2-2 is the way to go. I have 1.5" pipes with reverse cones as mufflers and its loud...almost too loud.
Anyways, im looking forward to see how you go with build!
Thanks. Checked out your build, looks great.
My dad and I are doing this as a father-son thing too. He worked at Honda shops when these were new, so he's been a great source for info (and work when I need it).
That said, we're going to take our time and be ready for spring riding....we hope.
Thanks for the compliment!
Just keep in mind, that a "winter build" usually turns into quite the project. Especially if its your first true build. Mine has been a solid 2 years in the making, and its still not "finished".
Get yourself an idea of what you want to build and just start wrenching. Dont forget to start a build thread and post yer progress!
It's nasty that's for sure. I have been slowly working on cleaning it up, just takes time and I only get a couple of hours a week tops.
Updated pics attached.
Got the front end switched out from the vf500, and got the back wheel mounted up. My help decided he wanted to 'ride' it after helping me work on it.
Sanded underside of the tank and found a few pin holes under the left side.
Got some polishing done on the case side covers, left side pictured. Oh, and almost forgot, started working on mounting the rearsets from the vf. You can see the linkage connected in the pic of the side cover.
Like I said, been working on it, just takes time.
We took a break to eat some junkfood with the family. Several tables of just about any junk food you can imagine, and everybody digs in. That's just how we do it.
