K & N fuel filters
trek97
No Custom Title
DTT BOTM WINNER
I had a lot of trouble w these cheap little extruded brass filters. Trapping air bubbles inside themselves and between filter and tank tap. causing fuel to stop flowing or restricted flow. So much at times. my bike would literally run out of gas. I would have to stop for a couple minutes and wait for them to refill. I tried placing em near carbs. then tap. in the middle of line...everything.
So I tried these K & N filters. solved my problems. I placed them vertical in line just under carbs. So when I opened tap. The fuel ran up through and pushed most the air out. immediately. just a little tapping on them w my finger worked the rest of air out. problem solved. They cost a bit more. $10 bucks each but you can back wash em w carb cleaner every spring and re use them. stainless mesh inside. I will let you know once I get some more miles on them.
http://www.knfilters.com/search/product.aspx?Prod=81-0231
