Kawasaki G3SS Ignition Problem
ClayM
So I just picked up a 1972 Kawasaki G3SS that didn't have an ignition. I purchased a used one, installed it (really basic 6 pin with 4 additional color coded wires), and now am completely baffled. The ignition is essentially working backwards. When the key is out, the bike will turn over and the taillights will work, etc. When I insert the key and turn it to what should be the "on" position, it kills the bike. Any idea what might be going on?
Sonreir said:
Yup. Sounds like you have the wrong ignition.
It seems weird that it would be "the wrong ignition." The pin as well as all wire colors match exactly.
xb33bsa said:
maybe you have the battery hooked up backwarsd :-[
Battery isn't hooked up, it's mag-neat-o.
If the ignition switch is the correct one, then you have multiple short circuits in your wiring harness all located such that they allow the bike to run. Not impossible, but extremely unlikely.
Does everything work when the switch is off but nothing when the switch is one, or is there a combination of working and non-working items?
As far as I can tell everything works when the switch is currently set to "off", but I don't have a battery on yet so it's only when the motor is running.
Could it be that the wires are colored incorrectly and I just have a few crossed?
Sonreir said:
Do you have a wiring diagram you can post?
Here ya go. My bike is technically a G3SS-B as far as I know, so I found two very similar wiring diagrams.
OK... so using a multimeter lets do a couple of tests:
With the key on and then they key off, do you get continuity between the black/white and black/yellow wires on the ignition switch?
Tried a few more things. I can start the bike with with the ignition switch completely unplugged, but no lights etc. When I plug in the 6-pin, all of that starts working. I tried testing for continuity using a multimeter, but was unable to show continuity on any wires. This is my first time trying to use one, any pointers?
Being able to start the bike without the ignition switch plugged in is normal. The ignition switch kills the engine by creating an alternate ground for the magneto (rather than through the ignition coil). If the ignition switch is removed, then no ground can be created and the bike will run.
