Keep blowing light bulbs. Battery too small?
rubyroo
I've got an 81 gs 550 that keeps blowing one filament on my headlight and the one for my tail. Bike is kickstart only and stripped down of a lot of electrical stuff. I've got headlight/tail light on the same circuit, brake light is on its own. High beam works, brake light works, tail and low keep blowing. Not blowing any fuses.
Replace stator last summer and switched to a modern r/r as well. As far as I can tell it's working correctly. Using a 12v/5ah SLA battery from an emergency exit light. I've killed 2 of these; they end up with zero charge and zero resistance once they are cooked. Am I right in thinking I need a larger ah battery, probably one made for the vibration s of a motorcycle?
It's a.. sh775a? I think it was. A series r/r for polaris atvs. I've got stator wires in, positive goes to a 30 amp before Teeing off to the battery and ignition switch. Negative tees off to the battery and my main frame ground where all other grounds terminate. I get a little over 13v at idle goes up to 14-14.5 with revs.
Hmmm... voltages sound about right and I've used a similar battery before with no problems (on my Honda 360).
Does it hold at 14.5 with revs or does it keep climbing?
Holds, though given all your r/r questions maybe I'll take a second look. I did a quick check to look for shorts and see if things were in the ballpark haven't throughly checked it since the repairs last season
Another issue could be load dump. Loose wires could cause a momentary disconnection of a high load component and this will cause a temporary voltage spike (usually around less than half of a second), but it can be enough to blow bulbs. Most common culprit is a loose wire for the battery connection.
That seems plausible I really don't like spade connectors to begin with, especially didn't like the way the ones to the battery fit.
