Keihin VB22s idling problems
parrainx
Hello dotheton members
I've recently rebuilt keihin vb22s on my 82 cm450e and now i got idling problems. It idles really slow and when i try to compensate with big knob to adjust throttle opening it starts to back fire thru carbs making then pop out of their boots.
The set up right now is
Air screws 1 3/4 out
Primary main #72 (stock)
Secondary main #117.5 (stock one is 115)
Needles r raised two notches.
Bike has pods and removed under belly collector with straight pipes welded to untouched mufflers.
Accelerator pump stop is adjusted to spec and the bike runs perfect in mid range and wide open throttle. But it pops alot more on decelleration now after rebuilt and the pops r snappier.
It also does little pops once the bike is warm at idle but it doesnt always do it.
I have no idea what to do ive been playing with it for a week. I also took the carbs apart again to double check everything and it all looked good.
I would appreciate any help you guys can give me.
Thanks
I have zero experience with those carbs, but a 5 minutes troll in google land suggested that it's a common problem. Removing the air filters and eliminating the exhaust cross overs seem to exacerbate it.
Try going up one size on teh pilot jets and see if that improves things. They sound lean at idle. Check the intake boots for air leaks too.
Pilot jets are the long ones?
Thanks
So i replaced #38 pilots with #42s and primaries with 75s, originally 72s.
Im still having trouble with slow idle. Im i suppose to turn out air screws more that 2 turns? Im off the idle screw completely now, but idles awfully low.
Do you guys think that i gotta go even bigger on pilots?
Thanks!
