Kerker slipon exhaust
splittie
I am looking to replace the slipon section of the exhaust on my bike.
While unloading it from a trailer it tipped on its side and the muffler section busted right at the bend. Looks to me as if there was already a bunch of rust inside as there were small pieces of it coming out through the hole. And instead of bending, it just cracked open.
Looking for a place to buy just the slipon or a slipon that would work from another manufacturer.
Any help would be appreciated
I would check ebay for a good used replacement exhaust. Another way to repair it would be to go to your local muffler shop and ask for a piece of scrap exhaust piping. They can bend it to any angle you like and even expand the ends to fit your exhaust, possibly slip it over the damaged ends and clamp both ends of the joint, or weld it. Usually they won't even charge you for it. I used this method for joining a mismatch muffler and set of headers on my bike and it worked out great.
Thanks for the info.
I was thinking of something along the lines of clamping on a canister from a newer style exhaust, but I am unsure of the reaction it will have on the performance of the bike
Using a newer exhaust muffler should not have any effect on the performance of your bike other than a different sound. Just make sure you re-jet the carbs accordingly. I used a modern exhaust muffler and a factory set of 4-1 headers on my bike. the two pieces did not fit together so I had the coupler made as I described before. I even took the opportunity to extend the exhaust a little for a longer drag bike look and angle it up a bit by putting a bend in the coupler allowing more ground clearance - came out nice and sounds good too. If I get the chance I will post a pic of it so you can see what I mean.
This is exactly what I was looking for. If you can post a pic that would be great
Thanks
