kick start wirring
yam81
hey not 100% on how to run the AC generator into the layout :-\, working on a 1981 yamaha SR250 (sure it would be the same for any other make and model though) do i still need the voltage regulator and the CDI unit in the wirring ??? thanks for any help
Jon
You need everything but the starter and its solenoid...do you have a wiring diagram for your bike?
CDI 'works' the ignition, without it your not going anywhere
If your keeping battery (may have to?) your going to need regulator and rectifier .
When you remove starter motor, you can only remove heavy wiring, solenoid (relay) and starter button switch.
You can fit a smaller battery but it sound like you should get bike running good before you go any further
Oh, go back to first post and change title to wiring
