Kickstart shaft diameter cb175
silverheli2000
Active Member
Hi all,
Hopefully quick question here but having a difficult time researching it. I need a kickstart lever for my 72 cb175. Here's the thing though, I have the original lever but due to my rearsets it hits. The type I have swivels at the top and I really need one that swivels at the bottom like the bigger cbs. I want this type so when I alter the angle to clear the rearset it'll fold out of the way. SO...can anyone tell me what kick start lever I can look for that swivels at the bottom and will sit my 175 shaft?
Thank you in advance!
Here a trick, go to a site that offers a fiche for parts. Then look at the listing for the kickstart seal in the rightside crankcase cover. The seal listing will tell you the inner seal diameter and the outer diameter. You can use the fiche to search various models in the CB range and era, chances are if the inner seal diameter are the same on two different models and years then the splines could fit. Then its just a matter to check out the shape of the kickstarter in the fiche to find one you might think will work.
