kill and starter switch question
laychooba
hey guys,
im in the process of rewiring my bike, and i'm tackling
the ignition kill system. i was just wondering, when the
bike is stock, can you run the starter button while the
kill switch is on?
Depends on the bike. Most bikes kill the starter circuit as well as the ignition when the kill switch is off, but not all. Just yesterday, I was starting a '73 CB350. I was cranking and cranking and wondering why it wouldn't start. Then I saw the kill switch was off.
yeah that's what i meant. my ignition is killed when the "run" is off, but
the starter seems to work whenever the ignition (key) is on. i don't remember
how it was before, but since i'm down here rewiring everything, i want to
set it up right.
My Suzuki GS450 kills the starter too when the kill switch is off.
Either way you do it is "right." <G>
set it up right.
Get a manual. Without extensive experience in wiring of that particular model/make it's an absolute no-go to dig in without a manual. Dont try, you'll make it worse 100%.
Most Honda's run the starter when killswitch is on, as the killswitch cuts power to the coils (black/white wire out to coils, black in from ignition)
what bike do you work on anyway?
