Kill switch diodes
teazer
Over 10,000 Posts
DTT BOTM WINNER
I have a two stroke twin with two separate ignition systems and one kill switch.
The bike did have a DPDT switch but it's big and ugly. I want to use a single kill switch from a pit bike but I am guessing that with both connected, the thing won't die when I push the button.
So I was thinking that I could use a pair of diodes on the two coil connections. Problem is that I have no idea what sort of diodes or rating I need and no idea what sort of primary voltage we're talking. It's CDI ignition but I don't think it take all the primary current to kill it. I think it just shorts out the pulser coil or one of the charge circuits.
Any ideas? Matt?
Reverse EMF is around 120v, trigger voltage can be anywhere from 90v to around 300+v
The bike is a TZ350 and ignition is Motoplat. Stock TZ ignition is a Hitachi CDI with a single black box containing two circuits arranged so that the kill switch shorts both to ground.
Motoplat is like PVL in that the coils contain the CDI circuit and connecting both together at the kill switch doesn't work. This bike ran with a DPST switch but it's ugly. In searching tonight for PVL kill switch arrangements I see that the solution is indeed a couple of Diodes, so I ordered a pack of 1N5408s - 1,000v 3 amp. They come in a pack/roll of 100 for about 10 bucks so it doesn't matter if I fry a few.
I see that Fast From The Past sells a kill switch splitter and I suspect that's the same arrangement I am planning. I just don't want to fry a Motoplat. I sent a fried one to Spain for repairs once and the answer was something along the lines of "you have got to be joking". It was pretty bad admittedly. On that system, the stator also includes a couple of electronic circuits, but there seems to be no easy way to unencapsulate them to check them out.
I'll let you know how that works out.
A tape of diodes arrived yesterday, so I soldered on leads, crimped on connectors and fitted a spare Motoplat on the test jig. At 1200 rpm, it throws 1/2" long bright blue sparks and touching the kill wire to ground just shut off the sparks with no drama. I'll make up a couple of spare units. It should work on the PVL or FEMSA as well.
This first one is not pretty and I suspect that the huge fat diode I used may be more than I need, but it's still a small package and it looks much better than a DPST hanging off the bars of a race bike. I wish I had though about it earlier.
Interesting. Electronics were never my thing but sometimes the old brain needs a good work out just to keep it ticking over smoothly.
Yep, I've probably learned more about electronics (as opposed to electrical systems) in the last 2~3 years than I ever wanted to.
It's kinda interesting how simple some 'real complicated' things can be plus just how cheap some of the components are (which makes loosing the 'magic smoke' a lot less frightening ;) )
Just realised you got some power diodes, 3amp is a LOT 8)
Fo sho bro, but I have zero idea how much voltage or current is generated in a Motoplat ignition at any sort of speed. The spark jumps an easy 1/2 inch at almost zero revs so that's say 40Kv and with a wiring ratio of say 400 turns to one and CDI of a bazillion pico farads, what is the current in the primary circuit?
You know what I mean ;) ??? :-\ So I figured go big and be safe. Diodes are cheap but ignition systems - not so much.
Ha ha, yep, know exactly what you mean.
I've been promising myself for years I'll make a peak voltage adapter for multimeter. You plug it into primary side and then can measure 'spikes' in voltage from reverse EMF.
Basically you charge up a 400v (or bigger) lowish uF capacitor and measure 'average' of the primary winding voltage after spark.
Harley were using the reverse emf voltage as a control for fuel injection around 2005~6? (I forget when they first used it)
Lean mix requires higher voltage which creats higher reverse emf volts in primary windings, opposite with rich mix
They knew the expected volts so used any variation to change mixture
