kill switch relay
primo
my stock kill switch for my cb350 twin broke and has been eliminated. i bought a killswitch button as a replacement that has one black and one red wires on it. can someone give me a step by step wiring instructions for the switch to work properly in killing the engine so that i can register my bike as street legal?
do i need a no closed relay in order for the switch to work and if so, which one (link please).
If your using a 'stock' 30A relay (as used for horns) , just wire the ground side through stop switch to open contacts instead of closing them (needs dual pole so one side is always 'ON')
Its actually a good idea as you get full battery voltage to coils through relay.
I don't have one handy to give you terminal numbers but you only have 2 sets of contacts so it ain't rocket science
PJ
PJ
Hahahaha. I blew two fuses before I realized I had my relay hooked up wrong.....and I am a rocket scientist! :D
pj, when you say dual pole, is that same as saying 2 prong for the wire to connect to from the relay body? also, would radioshack quality work?
Not sure if tthat will work, have no experience of it.
As long as there isn't an internal bridge its OK
You need one that will probably be 5 terminal (dual #87), about one inch cube, plus 'hang tag'
4 pin will work just need to split coil input wires from battery
I pulled apart a single pole (off-on)
Usually, main feed IN will be terminal #30
OUT #87, (going to coils)
#85 and #86 are control voltage, you'll wire one side to battery (through ignition switch) and other terminal to ground (through grounding stop switch)
That energises solenoid and allows current to coils.
When you take away ground, contacts open and power to coils is cut off.
Make sure handlebar end is well grounded, including bars to frame.
PJ
someone told me there may be a simple to kill the engine by grounding out the engine by connecting one wire of the momentary kill switch, like the one i have, to the positive wire of the coil. that way i don't need to purchase a relay. does this seem like a safe way to kill the engine? i don't plan on using it regularily but would like it so that i may pass the DMV inspection when registering to CA state. where do i connect the other wire that comes out of the kill switch for this to work?
Shorting battery to ground is never safe, thats what you would be doing.
PJ
