This may be kinda long to explain but here goes.
72 Honda CB350K4
Installing K&S switch 12-0052 which is a Honda TRX type OEM#35020-HN1-000. I choose this because it has all the features I need on the left hand control. I will not be running a right hand switch pod, just throttle tube. Anyways the issue is I do not have power to the coils on the B/W wire through the kill switch. I cannot find a circuit diagram of this switch assembly. It looks as though the TRX switch does not send power to the B/W wire. Can anyone confirm this? Is this because of the CDI box on the TRX? I tried to trace the power from the Blk wire going through the switch pod and it looks as though NO power goes through the kill switch, it only has a B/W and green wire attach to the actual sliding kill/run switch. The card from the pod lists B/W wire as "from kill switch (output)" and green wire as "ground (input)".
Thanks in advance for any help, I am kind of an electrical idiot.
Brent
72 Honda CB350K4
Brent
