The bike looks awesome. Do you have any videos?
rextec said:Looks great! Has a very well put together theme, flows real nicely. How do you like those rear shocks? Thinking about picking some up for a cheap little project i have going on.
MILLENNIUM FALCON said:Yeah I used one of those universal cables. They are a pain. You need to measure to make sure everything is the correct lenght. I has to mess around with mine to get the slides to go full throttle and also close all the way to an idle. Once I got it all figured out I soldered the nipples on. Make sure you get a good solder because you dont want those babies popping of in the middle of no where,
Currently the inside of my battery box is a mess. Here are couple pics to show you how it's bolted on.7aliveatlast7 said:could you tell/show how your seat and electronics tray is all attached? i'm interested in seeing others' ideas as i'm getting my wiring sorted and am ready to make a tray compartment under my seat. i have a game plan, but want to know what other options people have gone with.
diggerdanh said:Let me know how you get along with the Mikunis and the throttle cable. I'm just getting ready to start on the same project. What size did you go for? I opted for a pair of VM-30s. I'll have some pictures up later.
veaone said:The 2 into 1 throttle cable needed to run the mikunis is really hard to work with. Make sure you measure everything correctly. I made a mistake and measured it before the tank was on and now it's short, because the tank is pulling it down just a bit and one carb gets half way stuck. Soldering it was kinda tedious and it didn't want to fit through the nipple. Honestly I think they can come up with a better cable set up. As far as mikuni carbs go i didn't get a chance to fully test them. They are 32 round slide carbs. When the bike decides to start up it runs very rich. I will need to order new smaller jets and probably new cable.
