KZ 400 running just fine-little carb question
2_DONE_THE_TON
Over 1,000 Posts
DTT BOTM WINNER
Dear friends!
over the summer i restored a kz 400 (1979) twin.The engine is running just fine,exhaust is the original one.
I replaced the original filter box with two single filters(k+n).the main jet was enlarged (1 size).
after the first ride i removed the spark plug and checked the colored.the plug is brownish,but on the tip of the electrode there is a small white area(not the whole spark plug just the tip).
so my carb is running to lean?
is this just a question of fine tuning or do i need to rejet?
or is this normal and i dont even need to bother?
i heard that if the spark plugs burn white they can seriously damage the motor.
thanks ahead! :)
One jet size up when switching to pods is not even close. You can go one jet size larger staying with the airbox and be about right. I start at about 8 jet sizes larger than stock jet.
tanks for the quick answer!
will there be a problem if i stick to the jet.i just dont want to rebuild the carb.its running just fine.
she runs fine,revs up fine,and starts like a lady on the first push.
does the white electrode need to bother me?or is it just a question of fine tune?
Proper jetting is essential. Don't be lazy about it just because it's running "fine." Do it right, or pay the price. Hate to see you burn a hole through a piston.
Don't take too much stock in a plug reading unless you know how to do it properly.
Go rich on the main jet until it breaks up a little on the top end, than back off on or two jet sizes.
