KZ 400 wiring thread
Hey sonreir!thanks for the help so far!hope i can fire her up this weekend.
This is my LED plate light setup (2 LED screws with black and white wires).
Am i right that the ground side of the LED goes together with the ground and the plus side goes onto the brown TAIL cable?
Second question:
In my headlight H4 setup there is yellow white and brown on the H4 plug and brown white and yellow black on the parking light.
I guess they plug in power(brown) signal main(orange) and ground (black) or am i wrong?
Cheers!!
Question 3:does this ground cable go to bare metal frame or batt minus?
Tail light - Correct
Headlight - Signal main goes to the turn signal switch, not the headlight. The only wire that goes from the headlight to the harness is the ground (and possibly the pilot light, if you want it.) High and low beam go to the left hand control.
Ground to frame.
Did I remember to send you the installation instructions? Do you have a diagram?
Ground to frame.
thanks sonreir!
yes i have the manual,but the text is hard to understand for me.i got the stock diagram but i tend to ask too many questions.better safe than sorry :-)
Hey sonreir!
The tail if my loom is all connected,the front is connected for about 30 per cent.
When i connect the battery and turn the ignition key there seems to be no juice in the system.which cables are to be connected to check backlight,blinkers and the rest of the tail?
I guess the brown wire is the hot one,maybe i'm missing ground somewhere...
hey sonreir!
been really busy the last month with my RD and work but finally i had time to draw a newbie wiring diagram.will come handy in time,but i still have some questions left.
I marked the questions with red dotted circles,maybe you can take a minute to look over the diagram,i still have no juice on the tach et cetera.
1+ 7 how do i connect the left and right control assembly to your loom?i just dont get the description on your guidelines.
2 how do i connect the headlight H4 plug?
3+6 could you please check the plugs i made,i guess there must be something wrong.
4+5 how do i connect these two?
thanks in advance!!
Sonreir said:
Lets do one thing at a time.
First up, your tachometer.
It's LED, so each light will have a definite positive and negative wire.
The neutral (green) and oil pressure (red) wires will be activated by a switched ground. This means the green/black goes to the neutral wire and the red/black goes to the oil pressure wire. The green and red can be tied together and connected to a power source (along with the power for the gauge back light(orange?) if you don't mind having it on all the time).
Ground wires (the ones with the black stripes) for the high beam light (blue), turn signal light (yellow), and gauge backlight (black?) can all be tied together and grounded.
This leaves the power wire for the turn signal indicator and the high beam indicator. High beam is the easy one (blue) and can be tapped into the high beam wire. There is usually a plug for this in the headlight as part of the pigtail but may also be attached to the left hand control assembly.
The turn signal (yellow wire) will be the tricky one. With an LED setup, you'll need diodes to provide a one-way signal to the indicator light. I can't remembered if you ordered this option when you got the harness, but it will be an orange and a blue wire heat shrinked together with a black wire coming out the other end. If you didn't order it, you're going to need to get some diodes and start soldering. Details here: http://www.dotheton.com/forum/index.php?topic=44556.msg486851#msg486851
Hey sonreir!!
I'm 90 per cent finished with my wiring!!
The only thing i didnt tackle yet is the dcc tach...heres how i connected the wires:
Green black to purple (neutral)
Red black to pink (oil pressure)
Black,dark blue-black,yellow-black tied together to ground
Green,orange,red tied together goes to power
Dark blue and yellow not yet connected (i ll need the diode setup)
When i switch on the iginition now,the tach lites up,all lights go on,but the idiot lights do not go out for example the red oil pressure,so its always on...
Any ideas whats wrong here?
Sounds like it's working correctly to me. If the engine isn't running, there's no oil pressure, so the light comes on.
Figured the high beam LED today,connected the blue to the h4 plug wire.
The only LED not working correctly now is the neutral.(for the blinker i will need a diode).
The bike is in neutral but the light doea not come on.
The purple netraul wire goes back to the pan where i hide the wires and then down to the motor.maybe i connected this purple wire wrong.there are 4 wires coming out of there.
hey sonreir!
i guess i will need a diode setup for the LED´s of the neutral and blinker idiot lights in my DCC mini tach.which kind of diodes would you use?
For a stock indicator light, both the left turn signal wire and the right turn signal wire connect to the bulb and the wires alternate as the positive and negative depending on which direction you're signalling. For LED signals, this indicator light now represents a crossover that will cause all four signals to light up at once, regardless of which direction you're signalling. The solution to this problem is to the polarize the indicator light by preventing current from traveling between left and right circuits.
This is done by treating the left and right signal wires, together, as positive and then adding a ground wire into the circuit. The current can be "forced" in one direction by the addition of an electronic component called a diode. A pack of three can be had from Radio Shack for about $2.
By removing the left and right signal lights from the indicator bulb and wiring a diode onto each end, we allow the current to flow into the bulb, but not back up the other side's turn signal circuit. After the diodes, the two circuits can be spliced together and we now have no worries about the crossover. The spliced section (shown in black on the attached picture) acts as the indicator light's positive side and the negative side gets a new ground wire that you will need to attach.
So last man standing is the neutral light,go everything working except the neutral.
When i connect the green black to the neutral wire and the green to a power source the control light doesnt light up.
Is it possiblr that i need a diode for this one?
No. I think the issue might be either the wiring or the neutral switch.
Disconnect the neutral switch from the harness, put the bike in neutral, then measure the resistance between the neutral switch wire and the negative terminal of the battery. You should get less than two Ohms or so.
Hey sonreir!is the way i measure this right?am i using the right settings?
The multimeter shows 1 if my settings are correct now....
Ryan, Check the switch - at the switch between the small screw that the lead goes on and ground. Test it in neutral and in gear. One should read some really small number (not 1) and in gear should be infinite.
If that checks out, make sure the LED is not back to front. Unlike an incandescent bulb, it only lights up connected one way round - it is a diode after all..
Test your multimeter by touching the two probes together. You should see teh reading change from open to a small reading. That's what you expect to see when you have continuity.
If that test is just for the switch, it's one of two problems.
Easiest to check is that your battery negative terminal is property connected to the frame. Repeat the test you just did, but instead of checking the neutral wire, read from bare metal on the frame or engine case.
If that test is OK, you have a bad neutral switch or a bad wire leading to the neutral switch.
Thanks guys for helping!i will check tomorrow when i'm back in the workshop.
Had a frustrating night yestersay trying to figure out whats going on with the switch.
Connected the switch with the ground of the control LED and the plus to power.
NOTHING.
Then i thought maybe i'm in 'wrong neutral' tried to shift around then the LED would always light up for 1 millisecond.
Then i put the bike on the kick stand.
It lit up permanently.shifted,went out,tried to go back in neutral,light does not come on.
Then i started the bike in neutral...light goes on after the motor turned over for a few times.
My guess is that there is malconnection inside the switch and it cannot fully engage.
How does switch work?
On my RD its a rotating pin connected to the gear when it hits the contact it grounds the switch,is this switch similar?
