KZ400 Charging Circuit
firebane
braaaaaaaaaaap
I've posted this up over on the kz400 forums but havent' received any response so thought I'd ask a few people here and see if they provide some answers.
I recently picked up a Ricks R/R for my bike and want to make sure that when I wire this up it will be done right. The image is what I have figured to be the correct setup for a charging circuit as the bike is going to be kick only.
My only issue is that do I need to worry about the brown wire and can I just feed power to the entire bike off the battery?
Here is an picture of the original harness: http://kz400.com/Techh%20tips%20bilder/Wiring%20diagrams/kz400%20S3.JPG
I think I have it correct but I just want a second pair of eyes.
I don't think your regulator will work like that. The regulator needs a voltage reference....the battery. If the regulator isn'tseeing the battery voltage, how does it know when the battery is charged?
If in doubt, ask Ricks Directly. I have questioned them on their product and they were very helpful and responsive.
It looks like I may need to run another line from the negative of the battery to the black coming off the regulator.
The ground (to chassis?) is good. the brown wire, if that regulator is like most PM alternator regulators, needs to see the battery +12V.
It does not beed to be directly on the the battery, in fact, on most applications, that is to switched 12V from the ignition key. As long as the wire shows the state of the battery voltage, you'll be good.
So upon some further reading brown is 12v switched. So it seems I would need to run the brown to one side of a switch and red from the battery to the other side to allow switched power for the bike.
This also looks like it would complete the circuit for regulating the battery voltage.
I updated my original post with a new image as from what I can understand the brown wire acts as a "sense" wire for the voltage required for the system. So as long as as its tied into a spot where there is 12v voltage then it should work.
