I have a 1978 KZ400 deluxe. It has an erratic idle once it gets hot and wont come down below 2000. It rides pretty good, but a bit of hesitation in the midrange. #2 cylinder is slightly rich, #1 looks perfect. There is some weirdness going on with the timing, I dont think its part of the problem, i only mention it to cover all bases. I set the timing per the FSM using a ohm meter to determine when the points are opening. However when i check it with a timing light it is advanced. I set it by idling the bike and turning the points plate until the marks line up. not sure why it does this.
Here is a list of the things i have done;
adjusted valves,
cleaned and lubed advancer.
set point gap
set timing
cleaned carbs THROUGHLY
carbs completely rebuilt, with OEM pilot jets
new diapraghms in carbs
replaced jet needle holders with used good condition ones off ebay
carb floats set with tube
carbs synced
new carb holders
Air box boots are hard but appear to be in OK condition, doesn't seem to be any leaks.
New OEM air filter
compression is good 150PSI on both
tested spark plug wires - good
new spark plug caps
new spark plugs
stock exhaust with new gaskets, no leaks.
I am at my wits end here, i don't know how to proceed.. heeellllppppp!
adjusted valves,
set point gap
set timing
carbs synced
new carb holders
New OEM air filter
new spark plug caps
new spark plugs
