kz400 ignition delete.
MILLENNIUM FALCON
Over 1,000 Posts
DTT BOTM WINNER
I have done a bunch of searching but can anyone just make this easy for me. I want to eliminate the key/lock cylinder on my 78' kz400. I want just a simple on/off toggle. There are 4 wires inside the stock switch. I believe they all make contact when the key is on. thanks
I believe you're on the right track MF. Can't really make it out on my phone, but basically pig tailling the 3 wires on the left of that harness to the white (?) wire and adding a switch to said white wire should do it.
May want to wait for some sharper eyes than my own though.....
It's not that simple. The main switch does more than simply turn the ignition and lights on and off, it does so in different combinations. You could do away with the PARK position and wire it more simply but then you need to add in relays for the lights.
And of course it's easier to steal without a key (slightly). I keep the ignition switches on custom bikes but sometimes relocate them under the tank or seat.
How about using and RFID proximity switch under the seat to work with an RFID "key" in your pocket. No visible On-Off switch
Thanks for all the input guys! I got it all worked out. I used a relay from a hidden switch to activate the lights and ignition. I am just trying to get it on the road right now. I may look into some of the other options down the road.
I know this is old. But could you shed some light on what exactly you did.
I am in the same process now. Seems simple enough but it's eating my brain.
Thanks
Funny thing is its been so long I cant remember exactly what I did....haha. I will take a look tomorrow and let you know. I know I hooked up a toggle switch...but the switch only powers a relay. I will get you better info once I look at it. Man I feel like my dad... "why am I in this room?" haha
Thanks
Ha, no worries. Really appreciate it if you can confirm. I'm 75% sure on what needs to be done. Just nice to talk to others who completed the same task.
