Architecterre
Was cruising the web and found a great resource for kz400 sprockets. Thing is, they have their sunstar rear sprockets priced different according to # of teeth. The 41 tooth rear is 55% off at the moment, and thereby half the price of the 45T. The original OEM ratio of teeth for the sprockets is 15T Front to 45T back (ratio of 3.00). Is 14T to 41T (ratio of 2.93) essentially a negligible difference or is there some type of negative associated with such a change. Figured I'd ask prior to making the purchase
can't hurt.
Also, if you have any other opinions on what sprocket setup I should be running let me know (lower or higher ratios). Also opinions on chains is helpful as I will buy a new one to mate with these new sprockets (o-ring vs non-oring, 530 vs 520, etc)
Thanks,
Adam
http://www.dotheton.com/forum/index.php?topic=43584.0
Thanks,
Adam
