KZ400 Tach wiring
2_DONE_THE_TON
Over 1,000 Posts
DTT BOTM WINNER
Hey guys!
i want to replace the stock tach section of my 1979 kz 400 with a dcc tacho that integrates all control lights in its face.
what are the cables coming from the three white marked areas for?
will it be possible to connect the new cables with the stock ones by a plug connector?looks like the dcc tach has more cables on it than the stock ones...
please help!
thanks in advance!
can't you find a wiring diagram of your bike? otherwise just take your multimeter to your electrical system to find out which wire does what...
i was just asking if anyone out there already performed that change with a KZ400...thought it could save up some time i could use riding that little bastard:-)
if its like my bike. not the same i know, but you will have the tach feed and your blinker and oil light in one gauge and the blinker and high beam in your other gauge. its just a matter of figuring out which wire goes to what. also check out kzrider.com forum. all Kawasaki all the time. there are several threads about wiring and factory service manuals.
Locate your model in the following link of manuals.
http://www.kz400.com/WorkshopManFrameset-5.html
If needed, I have a manual in my Google Drive I could share to you.
Find a wiring diagram that matches
Inspect each wire for it's function
Label each wire
Create your own new diagram with the part and it's wires mating to the bikes original wiring
Splice and wire
The solid color wires will probably match the color of the light they're meant to activate and the wires with the black stipe (but same color) are the ground wire.
So green will be the positive wire for the neutral light and green/black will be the negative.
I wired up one of these a few months ago and you're going to need to cut into the harness to get it right.
