KZ440 won't start, need help
cameron750
I've been spinning my head in circles trying to get my girlfriend's 1982 KZ440 to start. When we bought the bike, it would barely run or idle off the choke, and if you tried to rev it, it would surge and die. We changed the plugs and oil, and then I pulled the carbs off and rebuilt them. It has the keihin carbs with the vaccuum diagphram. Stock airbox, stock exhaust.
One of the mixture screws had been run in all the way shut by the previous owner and the head was stripped off, so I had to drill it out and replace it with the one in the carb kit. I have them set around 3 turns out from closed just to get a basic setting. I know it will run like crap when it does run, but that's neither here nor there at this point. Now that i've put them back on, the bike no longer starts. I will run if I spray starting fluid into the intake, so I'm trying to trace why it isn't delivering fuel.
The tank has fresh gas, doesn't look like there is any rust inside it (gas comes out very clean). The petcock works, but the floats aren't filling. I took the carbs back off and set them up below the tank and turned on the fuel. I waited about ten seconds and then took the float bowls off - no fuel. I turned the gas back off and fuel started pouring out like it should. What could be causing the floats not to fill up, or to intermittantly not fill? Carb kit included new needle and seat.
Am I going to have to track down another set of carbs? Also, has anyone ever done a mikuni conversion on one of these? I love the way my mikunis run on my GS and the fact that they don't rely on a 28 year old vacuum diaphram to work properly.
TIA,
Cameron
On a vacuum tap, ON and RES won't flow fuel unless the motor is running. You need to have it on PRI to flow fuel at rest.
I had as similar problem with my '82 kz1100. It took me takeing the carbs apart 3 times to get them to work. Its most likely the idle circuit. Make sure you go through every orifice and jet. Take a piece of wire from a wire brush and stick it in a matchstick to use as a tool to get into the little holes, or a piece of solid 30awg wire. Make sure you can spray carb cleaner through them and then clean out every hole with compressed air. Its very frustrating but I would clean them again. Take apart the choke setup and make sure all passageways are clear. Maybe try the boil in lemon juice trick. I haven't done it but heard good things. Good luck.
PRI is for prime, its the setting to use when the carbs are empty like hillsy said. Parts are still available avalable for these carbs, I replaced mine with a set of mikunis though
