KZ650 Bore Kit help
marclucarelli
Life is life!
This is gonna be a little vague because I have little mechanical knowledge. However, I've been thinking of purchasing a big bore kit from Wiseco for my 1978 KZ650. What I'm unsure about is whether or not I will be able to use the original cam or will I need to put in a new one? Also, what else might I need to do overall to the bike for this to work? Any input from you would be greatly appreciated.
Hope you are all having a great Holiday season!
You're best bet would be to go over to http://forums.kz650.info/. There are a number of guys over there that have done that kit and can give you some first hand experience. Great group of people there. Also, http://kzrider.com is a good resource.
If you are going to go with the 810 kit I would get some gpz750 cams. You might need to bore the cases but I think that is only if you are changing cylinders. Either way a better cam would boost power with or without a bore job.
650 big bore= 720cc,750=738cc
You can use the stock cams from the 650.
Or you can use the cams from a 750/4.
They are a direct bolt in with more duration and lift.
Make sure you get the ones with the tach. gear on the exhaust.
