Kz650 fiberglass seat attachment
beardcaller
Hey Guys,
I bought a '78 Kz650 a couple of months back and when i got it the seat was attached with just velcro. the mounting tabs or whatever they are called have been cut off and pieces of velcro have been attached to parts of the frame and their corresponding areas on the underside of the seat. the seat is a typical fiberglass cafe bubble seat. i do no have the seat pan for this bike and i was wondering if anyone had any ideas for attaching the seat to the frame in a more secure manner, however if at all possible still be able to easily remove the seat?
Thanks
tl;dr: fiberglass cafe seat attached to my frame using velcro, need mounting tips
I will post pictures soon
A lot of people use Velcro to attach a seat. Usually the only problem is the adhesive on the Velcro wears out.
Welcome to the site btw! Are you a turkey hunter?
I've been thinking of making my own fibreglass seat pan for my kz550 this spring. I believe there's quite a few guys that do just use industrial rated velcro on DTT. I've been thinking that some electrical conduit clips (pic posted below) in select spots would do the job nicely though.
Your seat mounting method depends entirely on if you need to have it quickly removable to get at electrics/fuses/battery or not.
@Big Rich,
I wasnt aware of that, most of the posts i had seen had used the old seat pans, thanks for the heads up that this isnt uncommon. I was just worried about putting too much stress on the fiberglass without some sort of structural support.
and i have hunted turkeys before but the username comes from a drunken joke about getting the singer of iron and wine to play an encore by calling out to his huge beard.
I think it's a valid idea. Rigging up some sort of hinge might be a better way to go if you're considering having it actually attached to the frame.
If you're worried about scratching the paint on your frame with the conduit clips you could always buy a little bigger and get some padding to line them with. Plenty of options. It all depends on what you want for looks, accessibility, etc.
I would go with hinges that you can un-pin. that way, you can fully separate the seat from the bike if need be.
On my old '78 KZ650 I bolted the fiberglass seat to the frame using the four battery box bolts. I just bought longer bolts so they could go through the pan and still reach the bolt holes.
I was contemplating just using the battery box bolt holes as well, but theres that ugly gap between the seat pan and frame if your seat pan is flat.
@RoadRash do you know of any examples of someone doing something like that? What type of hinges would work for something like this?
You can find hinges just about anywhere, where either the pin can be removed OR to pin is integral to one half of the hinge, and the 2 halves simple slide apart.
Here's some that slide apart (at the bottom of the page): http://www.sailboatstuff.com/cb_hingesEx.html
Another, in a different design: http://www.amazon.com/Length-Flush-Mount-Hinges-Steel/dp/B002DH811I/ref=sr_1_9?ie=UTF8&qid=1323272119&sr=8-9
Finally, here's a quick example of one with a removable pin: http://www.amazon.com/National-N208843-Removable-Broad-Hinge/dp/B002YOS570/ref=sr_1_2?ie=UTF8&qid=1323272119&sr=8-2
Bear in mind these are all just examples. There are better ones out there to suit your need.
I usually weld a set of tabs to teh frame with nuts on the lower side. Then I drill the seatpan and fit rubber insulators from the stock battery box or something similar to get enough height and to insulate the seat from vibration. Use screws with wide low heads to bolt it on.
For a bike with hinges, you could probably weld the seat half of the hinge to a piece of plate and glass that onto the bottom of the seat pan.
In some cases I just bolt the seat to the frame . CB160 and CB877 have seats which slide on over a peg and are bolted only at the rear. We replicate that by slotting the front of the seat and arranging a suitable weld nut on a bracket/tab at the rear.
Velcro is fine for attaching the seat cushion but not for the seat base.
