kz650 mille
anarki650
Ran into some major motor issues with my kz, she started burning A LOT of oil so I ran compression and had 1-4, 115, 145, 175, 150. Definitely something wrong with the #1 cylinder so I tear into the motor to find out what. My valves ALL failed a leakdown test, after a top end rebuild less than 3 years ago, and my pistons and cylinder walls were all looking rough. Not gouged and majorly shot, but worn and needing some love at the very least.
After looking for options, the most insane option came looking for me. One of the guys over at kz650.info offered up a fairly fresh KZ1000 motor for a steal, and me being me I decide that's the best way to go. Did some research and the swap has been done and documented a couple of times, I was able to find a couple of threads that walk through the process on kzrider, and verify that the motor will fit (barely) without major frame modification.
I should have the motor in my garage by the end of the week and will start posting fairly regular updates (as regular as budget and time allow anyway) on the project. My goal is to have her screaming down the road for next season. The frame will definitely have to be gusseted, and I'm exploring some swing arm options to keep the rear end solid.
Stay tuned!!!
Wow, that is a very cool idea, swapping in the 1000 cc motor. One of the things I've always loved about the early cafe racers, Tritons, Norvins, etc. is the engine swap. Please keep us posted on this!
Scott
This project just keeps getting more and more intensive!!! Got the 1000 motor and measured mounting points. Looks like it's going to fit into the frame with minimal modification to mounts. I'll have to adjust the spacers on the upper rear mount and grind out about 1/4" on the front upper mount to make it fit. The lower center mount is going to take some plates and spacer from the looks of it, but shouldn't be too hard to get those just so.
Started thinking about beefing up the motor before stuffing it in. Might be a little crazy but I just can't help but be in love with the idea of a mildly built mille in this little frame. I'm thinking of doing heavy duty valve springs, mild to moderate cams, and big carbs, along with keeping pods and some as of yet undetermined free flowing exhaust (might go with a V&H Sidewinder just to keep clearances good for cornering). Between the 1000 cc plant and the mods I figure I should get pretty close to double the stock kz650 hp pretty easy.
Contemplating doubling the hp got me to thinking about having too damn much power for my suspension and brakes so I got to thinking about fightering her out. Started looking around and sourced everything I'll need to do that off 99 zx6 (pretty sure it's from a 99, might be a year or two off from that though). Next week I'm getting swingarm, rear wheel with brakes, rear suspension, front forks, triples, front wheel, front brakes, clip ons, rear sets. Everything a guy could want to turn a 32 year old bike into a mean ass corner carving, stopping on a dime bike. With that conversion done I won't hesitate at all to stuff the mildly built mille into her and give her hell. Running that set up will let me run my buddies take off track tires too, and at just over $100 a set can't really go wrong there!!!
Wish I had some pics to post of progress, but I haven't had a chance to do much besides plan the work at this point. Lots of pics once I get the work started!!!
Finally got the chance to actually do something with the old girl. Got the running gear mocked up. The zx6 front end is going to be pretty much a direct bolt up. I'll have to either switch the steering stem bearings or the races to get them mated correctly, but the stem is the right diameter and length and everything is going to bolt right up.
On the swinger I'm going to have to machine out the holes in the frame for the pivot bolt as the zx6 uses a thicker pivot bolt. It's not a huge diameter difference and it doesn't look like it'll be horrible to get right. Other than that I had to ditch the center stand to make room for the lower mount for the monoshock. I haven't started fabbing the monoshock mounts yet, but looks like it won't be horrible.
I got my bigger carbs for the 1000 motor, will be running BS34s instead of the VM26s I had on the 650 (which are actually stock 900/1000 carbs but too damn small). I picked them up for a pretty decent price ($150) and they look pretty much ready to run. Might have to rejet them depending on my final configuration, and they'll definitely need synced, but they look clean and ready to roll.
Decided that I'm going to run an Acewell (or similar) all in one gauge when it's all said and done. It'll be nice to get the accuracy of electronic gauges.
Haven't done anything with the motor yet, other than source the carbs. Once I get the suspension mounts fabbed up and have a good solid roller it'll be time to tackle the motor and source my cams and exhaust. But for now here's a pic of the roller mocked up. I'm getting excited about it!!!
