KZ750 BS38 Carbs
doc_rot
Oh the usual... I bowl, I drive around...
DTT SUPPORTER
DTT BOTM WINNER
if you are looking for carbs for your big twin, look no further. These are probably the cleanest BS38 carbs you will come across....ever. No expense spared in refurbishing them.
>Ultrasonically cleaned
>new gaskets
>All new Mikuni jets, including the one year only (1980) pilot screws
>Proper OEM needles and needle jets not the generic ones that come in the rebuild kits
>New Diaphragms
>most fasteners replaced with stainless socket cap screws
>many parts replated in bright zinc
>custom stainless float bowl drain plugs, M6-0.75 - unobtainium in stainless
>hell I even replaced all the e-clips with stainless e-clips
They work great, and look fabulous. I had them dialed in on my 1980 KZ750 running a 2>1 exhaust and K&N filter in the airbox. These carbs will fit 76-80. Comes with several different main jets so you can get these dialed in to your bike. These main jets are hard to come by.
The only reason I am getting rid of them is I built a hot engine and the carbs were the weak link so I swapped for flat-slides.
I'm asking for $350 which might seem a bit high if you hop on ebay and see the few junky carbs on there, but then you're stuck with some dirty carbs that wont be as nice as this. located in Los Angeles
