KZ750E 1980
hauqt43
Has anyone replaced the front brake master cylinder with a modern unit.
I've tried a Honda Hornet and a Yamaha MT09- none will work with the old Kawasaki calipers.
I've replaced the piston seals and dust seals on the calipers and in the meantime, I've fitted a master cylinder over haul kit to the old Kawa unit- the lever isn't great as there is corrosion in the master cylinder bore.
Is it possible that the modern calipers are more efficient and don't need as much fluid per stroke from the master cylinder?
Regards
Master cylinders have different bore sizes and it’s important to match them to the calipers.
I can’t proclaim to know how the math works but I do know MCs need to be the right “size” to operate your caliper properly.
Pretty much any newer conventional M/C will work as long as the bores are the same ie 5/8” = 5/8”. I’ve not really messed with the radial M/C’s so can’t help much there.
Later, Doug
