Lacing wheels
MILLENNIUM FALCON
Over 1,000 Posts
DTT BOTM WINNER
I have searched but cant seem to find a good thread with a break down on lacing a 36 spoke wheel (drum).
I am a visual learner so pictures would be good thanks. Could someone point me in the right direction. Thanks
I don't have any pics, but there are videos on youtube.
The spokes will have 2 different shaped heads- inner and outer. Then look at how the holes look on the wheel. They will point different directions and correspond to the hub.
I dont know why I never thought to look on youtube! That made my life alot easier. Got her all laced up. Thanks for the help.
Doing the first one takes a bit of headscratching but once you see the pattern and realize that it can really only go together one way it becomes a fairly easy job. Truing can be frustrating but that's another story. There are a few different ways to go about it, but what worked best for me was to lay out all the spokes in the hub and hold them in their approximate positions with small zip ties. Then the rim can be slipped over the spokes and the nipples installed to retain them. After that, onto the truing stand. I've laced exactly one set of wheels so far in my lift, so I'm hardly an expert or anything. However, if you take your time and think before you act it's not as bad a job as it seems.
Here's a page I found useful:
http://www.dansmc.com/spokewheels.htm
My front hub with the spokes zip tied in position:
Rim installed:
Yes this thread has been most helpful. I started truing it. I have it dead on from side to side, but it seems to have a little up and down runout. When I look at the top of the rim it goes up and down slightly. any tips on smoothing it out.
hotobucket.com/albums/j336/captain_neto/lace007.jpg[/IMG]
Here is a shot of my ghetto truing stand. I tried to show how far my wheel is out. I took a picture when my high tech ;D indicator was just touching the rim, and one when it was at its farthest point. What is an exceptable tolerance? I still am having trouble with truing it vertically.
If its anything like a bicycle wheel, which i imagine it is, when you find the high spot (where its farthest from the indicator) you loosen the 4 spokes closest to it a quarter turn (2 spokes going to the left side of the hub, and 2 to the right), and then opposite the high spot, tighten 4 spokes. After you get the hop out, you will probably have to re true the wheel laterally. repeat until true. getting a wheel perfectly true takes lots of patience and a couple beers.
All rims will have a bit of "hop" at the weld where the rim is joined to itself. Tighten on high, loosen on low in small increments. Patience, the right frame of mind and +1 to beer.
Ditch your open (unsheilded) bearings and buy the same size in 2RS (rubber shields on both sides). They are cheap, keep your hub and wheel clean and do not require maintenance.
Tolerances on my Honda are < 2mm from highest to lowest spot. My dad's old Harley says < 1/16". My guess is all spoked wheels fall somewhere right around there. I highly recommend getting a machinist's dial as your "indicator" is a great start, but probably not precise enough. They have them at Harbor Freight for about $10.
Yeah I have a dial indicator, the pencil was just a quit check. (I was being lazy). I have not had much time to sit down and work on it. Thanks
Ok now i'm doing the front wheel.... :'( It has me stumped. It has 40 spokes. Does any one know the pattern for a 40 spoke wheel? The videos I found on you tube were for 36 spoke wheels. Thanks.
It seemed like it was the same but, When I got toward the end the dimples seemed to be pointing the nipples in the wrong direction.
I wrote something up earlier... hopefully it's of some use:
Sonreir said:
Most of the guys I talked to lace their wheels in one of two ways. The first group will lace the inside spokes first, following by the outside spokes. The second group (of which I am one) prefer to lace all the spokes at once. The first method has the advantage of being able to see what's going on a bit better, but I believe that having the inside spokes in place makes it harder to do the outside spokes. The second method requires a bit more setup, but takes less time once everything is setup. For the purposes of this document, we'll cover the second method.
To begin with, you'll want to put all the spokes through the hub with which you are working. Ignore the rim for now. Spokes come in two varieties: 90° bent ends and 45° bent ends. The 90° spokes are for the outsides of the hubs and the 45° are for the inside. Once all of the spokes are threaded onto the hub, place the hub onto a flat working surface that give you plenty of room. I prefer the floor, through a small circular table will work as well. You'll want to be able to get all the way around the hub without having to move it.
Once the hub is flat on your working surface it's time to arrange the spokes in their lacing pattern. Although it's possible to have many different patterns for lacing, your pattern is likely to be a standard one of crossed and woven spokes. What this means is that each group of four spokes will be roughly perpendicular to the spoke beneath it and the inside spoke from one side will be parallel and adjacent to the opposite outside spoke. In order words, try to imagine this pattern looking from the top of the hub, down. The first (outside) spoke will heard off in the clockwise direction by approximately four holes along the rim.
The second spoke on this side of the rim (inside) will go counter-clockwise by four holes.
The next spoke (inside from the opposite side of the hub) will follow the first spoke in the clockwise direction, but will sit "above" the second spoke. The last spoke (outside on opposite side of the hub) will go in a counter-clockwise direction. Continue to follow that pattern of arranging the spokes until they are all pointing in the correct direction and the inside spokes are crossed over one another.
Now, place the rim over the hub and woven spokes, doing your best not to disturb the pattern too much. Pick a starting point and place each spoke through the corresponding hole in the rim. Screw each nipple onto the rim a couple of turns. You don't want it to be right at all, you just want to keep the spokes from flailing around. Continue this process all the way around the rim until all spokes are secured. Go around again, making sure each spoke nipple is hand tight.
Congratulations, your wheels are laced up. First timers: count on about two hours to do both wheels.
Thanks for the tips. I just finished it. I had been using the insides first method, but I really liked putting all the spokes in at once. It really takes the guess work out of it. Thanks again
Anytime, man. On the first one I did, I tried doing the spokes in two parts about four or five times before I just tried them all at once. I found the latter method to be a lot easier.
