Most of the guys I talked to lace their wheels in one of two ways. The first group will lace the inside spokes first, following by the outside spokes. The second group (of which I am one) prefer to lace all the spokes at once. The first method has the advantage of being able to see what's going on a bit better, but I believe that having the inside spokes in place makes it harder to do the outside spokes. The second method requires a bit more setup, but takes less time once everything is setup. For the purposes of this document, we'll cover the second method.
To begin with, you'll want to put all the spokes through the hub with which you are working. Ignore the rim for now. Spokes come in two varieties: 90° bent ends and 45° bent ends. The 90° spokes are for the outsides of the hubs and the 45° are for the inside. Once all of the spokes are threaded onto the hub, place the hub onto a flat working surface that give you plenty of room. I prefer the floor, through a small circular table will work as well. You'll want to be able to get all the way around the hub without having to move it.
Once the hub is flat on your working surface it's time to arrange the spokes in their lacing pattern. Although it's possible to have many different patterns for lacing, your pattern is likely to be a standard one of crossed and woven spokes. What this means is that each group of four spokes will be roughly perpendicular to the spoke beneath it and the inside spoke from one side will be parallel and adjacent to the opposite outside spoke. In order words, try to imagine this pattern looking from the top of the hub, down. The first (outside) spoke will heard off in the clockwise direction by approximately four holes along the rim.
The second spoke on this side of the rim (inside) will go counter-clockwise by four holes.
The next spoke (inside from the opposite side of the hub) will follow the first spoke in the clockwise direction, but will sit "above" the second spoke. The last spoke (outside on opposite side of the hub) will go in a counter-clockwise direction. Continue to follow that pattern of arranging the spokes until they are all pointing in the correct direction and the inside spokes are crossed over one another.
Now, place the rim over the hub and woven spokes, doing your best not to disturb the pattern too much. Pick a starting point and place each spoke through the corresponding hole in the rim. Screw each nipple onto the rim a couple of turns. You don't want it to be right at all, you just want to keep the spokes from flailing around. Continue this process all the way around the rim until all spokes are secured. Go around again, making sure each spoke nipple is hand tight.
Congratulations, your wheels are laced up. First timers: count on about two hours to do both wheels.
