leaking gas
ph!L
hey guys my 71 cl350 is leaking gas. It varies form a few drops to a decent puddle under the bike after i have been riding for a while. All the primary lines going from the tank to the carbs are fine along with the line connecting the two sides of the tank. The gas drips from the bottom of the swing arm and it seems like the only way it would get there is the lines that hang out from the bottom of the carb bowls. Has anyone had any experience with something like this?? or have any ideas on what it might be?
Thanks,
Phil
Thanks,
Phil
Its coming from the overflow lines from the carbs. Time to pull and adjust them. Get a float tool, you'll need it. No biggie.
Have you ever cleaned the carbs? Sound like one of the floats may just be sticking! Easy fix and cheap. Somewhere in 1-800-CAFE-HELP is a thread about cleaning in lemon juice and water. Try it, it works! May solve more problems than sticking float too!
Last but not least!!!,,,cb-cl keihin things ::),,remove the float bowl,hold it in your hand level,fill the bowl with LIQUID,with float drain closed...if it still pisses LIQUID the brass tube in the float bowl is split :o,,,,,they fill with water(barn or fence storage) and freeze and the tube splits,,,,,,and dumps fuel,,,,,,,,,,check the other suggestions first........scratched my newgen to figure that one out many moons ago ???
thats awesome advise! I have a four-wheeler that is pissing fuel and I have rebuilt the entire carb and cleaned it twice! Still pissing, This may be the solution! Thanks wee-tod!
