duggyb
where are the skis?
Well had my bike out for its first real ride tonight and got it up to temp. Along with the build I also did all new gaskets and fresh rings/hone bead blasted pistons and stone ground gasket surfaces.
Base gasket seems not bad a little sweating but looks normal.
Head is leaking in 2 spots. Both by the bolts on the outside.
Valve cover is leaking in two spots (could just be my job putting the grey gasket maker on?)
Generator side cover is leaking from the bottom.
I'm running AM SOIL 10w30 motorcycle oil.
Wrong oil? Do I need to re torque the head? Should those outside bolts have some sort of sealant applied? Where did I go wrong?
Thanks
Dustin
Sent from my SGH-I337M using Tapatalk
Thanks
Dustin
