leaky float bowl
primo
my left float bowl leaked gas after rides at the overflow vent valve (73' cb350G twin) so i swapped the left with the right to test out the bowl. now the leak is at the right. so i'd like to replace it with a good float bowl that won't leak.
someone pm me if you have a good non-leaking carb bowl that'll fit mine for cheap. which years and models would be compatible?
thanks
JP
If it's leaking from the overflow you could try replacing the brass overflow tube. For some bizarre reason they are rolled and wind up leaking at the seam. This worked on my CM400.
where does one get a replacement? do you just twist it off? wouldn't that tear up the body?
i'd rather get a replacement of the whole bowl unless i'm mistaken
Exactly what part of the north american continent do you live in......I should have at least a half a dozen on these bowls kicking about.......and knowing the problem quite well,,I can test them,,,,,,,Pm me
