LED for instrument cluster backlight
Big R
Heaven is so far away.
Here's my dilema: the 68 cl175's don't have a regulator and if I run my headlight in the morning, the higher rpm's are frying my led backlight (I'm pretty sure anyway)
Is there a way to add a regulator to the system or is there an LED that can handle more than 14.5 volts? I got that number from superbrightleds.com - not testing the output at high rpm
Couldn't you just add a resistor in series and right before the led to reduce the voltage it sees.
yeah exactly... or just add in a 12v regulator right after the rectifier... in the same place it is on the other cb's.
my option is better since it protects the whole system :D ;)
I agree, makes more sense :D
Rocan is right just follow the schematics for other CB ( like my 450 for instance ) and put the regulator after the rectifier where it belongs.
