LED Headlight Project
Sonreir
Oregon
DTT SUPPORTER
OK... so I'm starting on the fabrication and construction of my own LED headlight. This will be kind of a slow project as I'm mainly focused on getting my bike back on the road, so I expect I won't be done until mid-winter or so. Maybe ever later...
The main goals of this project are as follows:
  • Decrease in power consumption over stock incandescent bulbs (both high and low)
  • Match or beat lumen output of OEM headlight
The list of materials I'm expecting to need:
  • 7" Headlight shell (already have one)
  • 7" Headlight lens
  • Fiberglass cloth, resin, and hardener
  • Sandpaper, body filler, and glazing putty
  • Primer, Metallic Paint, and Clear Coat (all enamel-based)
  • 64x 5mm white component LEDs (rated at 3.2V-3.8V and 20mA - output of .5 lm, each)
  • White Cree MC-E Star LED (rated at 12.8V-13.6V and 350mA - output of 430 lm
  • Solder and assorted loose wires
  • Passive heat sink from an old computer
  • Small machine screws to secure main LED to heat sink
Tools I'm expecting to need:
  • Soldering Iron
  • Dremel Tool
  • Bench Grinder
  • Drill
  • Small diameter tap
So up first, we need to figure out the wattage draw of the OEM headlight in both its low and high settings. I really should be scientific about it and actually measure the draw, but I'm going to go with what the manufacturer says and assume 25W for low beam and 35W for high beam. When it comes to satisfying goal number two, I'm going to be even less scientific. I'm just going to take a picture of the OEM headlight shining down the driveway and then compare it to a pic of my LED headlight shining down the driveway and then decide whether or not I hit the target.
To start, I've decided on a design. According to the design I've chosen, my low beam will draw 15.36 watts and the high+low will be 19.56 watts. Definitely under the OEM specs.
I plan to use the attached template to make the reflector for the headlight. The red circle around the outside represents a circle of wire running at 12V DC. The black circle on the inside is ground. I will run 16 parallel pathways of LEDs from the positive to the negative wires and each pathway will contain four LEDs wires in series. In the middle of the reflector (currently marked with a red dot) will lie the 430lm Star LED.
The reflector will be made out of fiberglass which will then be cut and trimmed into shape. I'm hoping to make it slightly convex, but I'm still working on that. Maybe a mold or something... After curing, the fiberglass will be sanded smooth, bondoed, sanded smooth again, glazed, sanded smooth a final time, and then painted. The plan for paint will be primer, followed by a base coat of metallic enamel, and then a clear coat. It won't be a mirror finish, but it doesn't have to be. LEDs are quite directional in their lighting and the reflector will be more for style and less for function.
Hopefully, I can find a lens made of plastic or polycarbonate so that I can sand it to act as a diffuser...
I wish you both luck and prolonged sanity in your venture. I have toyed with the idea myself, but haven't been so brazen or bold. Hazzar sir...
Well if it is both functional and effective I have no problem making some more. I'll keep this thread updated as I progress...
High Beam LED ordered ($23.06) - http://www.ledsupply.com/creemce-w430.php
Low Beam LEDs ordered from eBay ($.03 x 64 = $1.92) - Had to order a pack of 1000 of them to get a low per unit price
Estimate for paint, fiberglass, and other consumables that I already had lying around: $7.00
Aluminum Heatsink ($6.99) - I already had this laying around, but there's a few dozen on eBay all for this price
7" Lens - I found a few on eBay between $10 and $20. Not yet ordered.
Heat sink polished up to ensure good contact between it and the Star LED (high beam) . These high wattage LEDs produce a bit of heat and the heat sink is mandatory. I polished to ensure good contact because, being inside the headlight bucket, there won't be a great deal of air flow. I want the LED shedding as much heat as possible.
Can't wait to see how this evolves.
You might consider integrating some amber LED's on either edge of the reflector to act as signal lights. I had a 7 inch H4 bucket that had 17 amber LEDs on either edge that worked like this, but it broke. Cheap overseas junk.
If you use a flat reflector perhaps you could use self-adhesive aluminised Mylar sheeting - its super tough and highly reflective. I intend using it for my LED taillight and maybe now (following your example) for a headlight.
Crazy
OK... so a cheap drill bit screwed up my first heat sink so I salvaged another off the north bridge of an old motherboard. I sanded it and polished it again and drilled the holes using three sized different bits so not as to eff it up again. High beam LED is now mocked up. Next step will be to get some nylon washers so my mounting screws don't short past the LED. Then I'll need to run the wires through the additional holes I've drilled and then solder them to the LED.
Looking good! I was wondering though, I bought a Stanley LED spotlight for 40 at lowes last month and that this is BRIGHT for being the size of a beer mug with a handle, if you could somehow take the guts out of it and use the 12v on the bike to supply it instead of the rechargable battery. Also it has a dimming/brighter capability built in and could be used for HI/LO beam if someone had the know how (ie you).. Just htought I would share my though. Keep up the build! I think LED would be great cause I was going to just use HID but this would be way cooler!
Best of luck to you. You may find that you'll have better results with fewer LEDs if you use better reflectors and optics. It would certainly save you a ton of soldering for one thing. Also, bear in mind that a standard H7 bulb only throws about 1450 lumens. A single SSC P7 can throw 900 lumens at 12W. I've thought about doing this myself, and my plan was to use only 3 SSC P7s in a triangle pattern. Two would be the "low" beam and would have narrow optics on them to keep the beam pattern low and on the pavement. The third would be the "high" beam mounted above the other two and have a flood optic on it that would fill in the background. I could probably fit these into a regular 7" headlight bucket.
One thing to keep in mind is the law. Technically LED headlights can't be used on the street. Offroad only. But I'm sure we've all seen a fighter or two that runs them.
One of the cheapest places to source parts is Deal Extreme:
http://www.dealextreme.com/c/flashlight-diy-parts-tools-917
Yes, it's a chinese wares reseller, and yes it can take a while to get your order. But I've ordered from them before and have been quite happy with the results. I built my own high powered LED bike light out of a flashlight I got from them.
And if you haven't found it already, definitely check out the Candle Power forums. Specifically the transportation lighting subforum:
http://www.candlepowerforums.com/vb/forumdisplay.php?85-Transportation-Lighting
ronnie,
You mean this spotlight?
pVltRZQiMGjKnaTa18n7e9edAHhPFq9q1Jyzb2Fmme7_ybUw0r4DYhPX0HkSTBPnbyfYCUTx8uE2vCtdx2vBhf76M4bhARmkNC01X7Ll2Ue-Ef-4U4njkW8eo8kNbidKUmtIZiZdKYTaTdAOqArvanSGJdCal-jT_BhZ_5c15w_FIEvLjEmnKMas-WENdL_KFj-0KLqVgH78REb3APvxed0LH7ZKr_iX9Yw5lSuYrJE8twqFxCtaL9mJxHQt2NUZYRLKpcilqCoWNzdpOzVc654Tc8bmsB6DDmV297v5xP3aNtokKUh2
If so, there are a few differences between my approach and theirs. For one, my highs + lows should put out about 450 lumens whereas that spotlight only puts out 192. I'm pretty sure their spotlight is very bright, but the thing about lumens is that it's a measurement of light intensity over an area. So it's very easy to have a bright spotlight with a low lumen rating but not so easy to have a bright headlight with a low lumen rating. Secondly, being a spotlight, it might not spread the light over enough area to be useful while riding.
flatcurve,
Thanks for the info, man! I'll admit that your triangle approach is almost definitely a better design to this problem, but there are a few other goals I had in mind. Most importantly, it had to be cheap. At close to $30 a pop, the LEDs of the "triangle" design would have cost close to $90. Also, I wanted kind of an "Angel Eye" effect with the component LEDs and so I'll be getting through a lot of solder... lol
For angel eyes you need say a VW Jetta that doesn't need to be perfect and peel the angel eyes out of that. As long as you can get it cheaply enough from say a local body shop or if you know someone at a dealership that has replaced a slightly damaged one for an owner. The old one is scrap to them and useful for your project.
I think that you can buy Angel eyes now on fleabay but it's been a while since I looked.
Yea, thats the one I'm talking about.. I didn't realize it was only a 192lu. Yea, I understand what your talking about with light spread. I was thinking more on the lines of using the LED inside it. But since its still a 192 you would need more than wha tyou already have. Thanks for clearing that up. I'll still be watching this project for sure!
i have built several tail light assemblies using leds and heat formed reflectors since you can make a unique light no one else has, keep it flush and draw hardly any current.....so good luck with the head light it can be done several ways and with a little time,basic soldering understanding, and proper electrical components(resistors,leds,diodes,variable resistors if you decide to run only one set of leds) you can do it................joe@ vcycle
Hey you say you heat formed the reflectors, I just bought a sheet of 1/8 red acrylic 15"x15" in hopes of heating it to mold around the inside of my seat hump. Is that possible? Any tips/tricks?
Don't mean to steal the thread, just a quick question..
