LED lighting
XsjadoTwin
So a friend of mine has a loca LED lighting business. And I was looking at his inventory and he has this LED light strip (about 30'....yes feet) in various size and frequency of LED's. So we hooked up the smallest and most frequent spool and fired them up... Sweet Jesus are these puppies bright! Its cuttable as well and the LED's are encased in a waterproof silicon "tube" (its more of a flexible silicon rectangle) all you have to do is seal up the other end once you cut it.
I'm going to be working with him to make some low profile tail and turn signal sets for my cl360. Ill get some pics of the strips in case any of you are interested in some quality LED's.
I'm also considering using the white LED's tucked on the inside of my frame for better visibility at night. But this might look a little tacky and very Harley riderish
Here's a rough sketch of my plan (the cross hatched area at the bottom of the seat pan will bend over and cover up the frame, I drew in an area for a cut out so it will fit over the rear suspension mounts. LED lights are designated in sharpie or fine line blue ink with a double dash.
Here's what I did on a Vstar I built up a couple of year ago, similar of what you're thinking. I made mine double banked for added visibility and even more brightness. Tucked in under the rear edge of the fender for a clean look. I'm thinking of doing the same thing to the GS650 I'm working on. Keeping it light, bright and minimal..
http://www.eastcoastphotos.com/gs650g/picture002.jpg
There are neat aftermarket LED packages available from CustomDynamics as well.. But as the OP has a buddy in the trade, I'm looking forward to what they will come up with for his bike. I plan to do mine up in LED lights as well, including the headlight. I have one on my VStar and they toss light out like it's no one's bidness.. wow. But expensive.. sigh
That looks great! If I had an upswept rear hoop I'd probably do exactly the same thing you did.
