Led signals
devon
They won't flash they just light up solid
I know Im missing something cuz I've read about it but for the life of me I can't find it!!
I know I could just wire in resistors but that would negate the benefits of led signal lights - what is it that I need to wire inline to make these suckers flash??
My bikes a 78 cb400t
Thanks,
Devon
Why do resistors negate the benefit?
Some have reported luck with solid state led compatible flasher relays from auto parts places.
if you are running the OEM thermal relay you will need solid state resitors. or you could go get a digital relay & that might do it.
Got mine to work with resistors wired in from radio shack. Then found another set of led flush signals for the side rear fender. When I added the extra LEDs it evened out the load and made the flash work right without the resistors I had a Yamaha relay handy if needed. You can usually pick one up for your bike for about 5 bucks! HTH
Resistors negate the benefit of LED's since they cause more current to be drawn. Once a certain threshold current is met, the old-style flashers will work again and adding resistors will accomplish this. However, if your goal is to use LED's to reduce overall power consumption, when you add those resistors they just bump up the current drawn and basically lead to nearly the same power loss.
I use the one of the motorcycle universals from SuperBrightLEDs on one of my bikes and they work just fine.
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fflashers.htm
They will flash with very low current (min. of 20 mA) being drawn so work fine for LED signals.
-jordan
