LED's - Is my thinking correct?
neevo
Over 1,000 Posts
Keen to put LED's on my build as the current draw will be a lot less, reducing the load on the charging system, and of course they look cooler. Few questions:
1. Assume a tail light/brake light is plug and play, no further action required.
2. Indicators will require an alternate flasher relay that works with the lower current, other than that it should also be plug and play
3. I cannot find any decent looking bullet indicators in LED without paying $200. Alternatively is it possible to buy LED bulbs in place of the filament ones that come in the units?
1: Yep.
2: Check out www.superbrightleds.com for relays. Not all flashers are created equal, and I've never had an issue with theirs at all.
3: Are you looking for bullet signals specifically? There are always tons of led signals on eBay. But you can get led bulbs that fit in your stock housings from the site I mentioned above.
I just bought an electronic flasher at Napa. It seems to be good quality. I also just bought two red led 1157 bulbs from superbriteleds.com that went into two bullet signal lights that I'm using as tail lights. Time will tell how they hold up. I have hear great things about superbriteleds.com
Yes from a shape perspective to match the rest of the bikes design. It seems like the non LED versions are nicer shape and made of metal, the LED versions seem to be either very cheap and plastic or very expensive or have the LED's exposed. Just looking for options.
Anyone had trouble fitting an LED bulb into a standard housing?
These are a nice shape but I suspect are plastic and I don't like the lens:
http://bit.ly/IasIHf
These are gorgeous but too expensive:
http://bit.ly/HlRW5W
Really nice too, but again very expensive and not very nice lens:
http://bit.ly/HlS70U
Anyone running something similar, small on their bikes that use LED's?
These might be the ticket...
http://bit.ly/Iaw0KQ
Billet (apparently), but the frame does look to be metal, and dirt cheap too so minimal risk. Just need to fab some spacers instead of those nuts and should be good. Anyone bought any?
Not bad PJ, I was thinking of replacing the mounts too, but with round stock not flat, and try and curve match the end where it meets the indicator body.
How are the indicators otherwise? Good quality? Still working ;)
working fine but chrome is peeling on one of them.
I had something rubbing against it and it was pretty damp outside so probably my fault as the other 3 are fine
