Lens tinting
Staffy
It's not yours 'til you cut it up.
Any good tricks on lens tinting, indicators, taillights etc? I don't wanna go too dark, just pull a bit of that amber and red out then fit amber and red bulbs.
I think I've seen spray cans at supercheap staffy? I think you spray the inside, but not sure? Let us know what you find out ;)
how useless was that info ;D
ian
You can get model paint in translucent amber and red. Go to a hobby store and have a look.
I used some once to re-finish a brake light lens on an old XY Falcon - painted on the inside it looked great ;)
I dunno about lifting the red + amber out, but I think it's VHT that makes a spray called "Niteshades" or "Niteout"...... something like that.
Or you can just paint it with black paint with the can about 2 feet away - it will put a layer of paint dust on the lense. But then you have to get really bright lights to shine through.
Is it even possible to make red and amber lenses clear?
What about a less permanent solution like an adhesive layover of some sort?
Something like this?
http://www.amazon.com/Bell-Automotive-V308-Lens-Repair/dp/B000P9S35U
I thought about getting clear lenses and just adding a circle of this stuff on the flat surface. You would still need colored bulbs though.
Nah, it would need to be bigger so i can do the whole taillight and indicators in one shot. Have you guys got "contact" in the US? That's what it's called here, it's that self adhesive plastic sheeting that we all used to cover our school work books in. I'm thinking if there's something like that, then that would be useful. I basically want to take the red and amber lenses and make them darker. I've just figured out that i didn't explain myself properly. *headpalm* I'd prefer something reversible too as the indicators on the fairing are bloody hard to find and worth about $50 a piece on ebay.
go to your local hobby shop, model masters makes a spray tint which is mush nicer and goes on a lot more even than the nightshades, the only catch is you have to clear coat it to last. make sure to scuff the lense with a green 3m scuff pad before any painting.
the things I do for you guys ::)
This is an old lens painted inside with a straight black, and reasonably heavy. I suspect the 'proper' paint would be more transparent? Compared with a stock lens.
this is what it looks like with the indicator on:
compared to the original:
I think you're SOL with a 'reversible solution hoever??
cheers
ian
Hmm. I don't think i'll tint em unless it's easily reversible as the boys in blue will defect the bike from time to time down here for stuff like that and it would suck having to try and dig up two new BMW indicators, which would be awkward and then the taillight is off an imported bike i was informed... grrr
Here's what i'm dealing with.
I reckon a flat sheet of tinting adhesive of some sort would work... if there's something out there....
How about some car window-tint type of thing? Not sure how durable it will be externally, but it may be your only choice if you want to revert? It's just applied with water I think? The front is a doddle, but those rears are going to be a pain. Possibly a 2-piece application?
ian
There's basically 2 kinds of window tint - 1 is the kind that uses soapy water (it's amazing how many people forget to use soapy water) and the other kind is the peel-n-stick. The peel-n-stick uses static cling is usually found on the top edge of windshields.
That peel-n-stick is also great for the top edge of a helmet visor. I have it on mine so when I leave work at 7 am the sun is right on the horizon the whole way home.
Go online or to a theatrical lighting supply store or your nearest friendly stagehand and get a few scraps of lighting gel. It comes is about 8 different shades of amber and red. stick it on with white Elmer's glue, which dries clear, or a few dabs of hot glue and Bob's yer uncle.
Terry
J'ville, Fl.
Staffy said:
Is it durable enough Big R? Many scratches in it?
What, the tint on the inside of the visor? It's above my line of sight - but yeah it's pretty durable.
VHT nightshade, its is a product I have used on a few applications now and I love it. It is a transluesent black spray that coats muck like clear coat from a rattle can. Cost about $10-$15 US and one can goes a long long way! Be sure to clean the lens well and wipe with alcohol, not acetone (made that mistake)! Each coat will get it darker and darker, for best results, hit two really really light coats at about 18 inches from object then hit a good heavy pass about 12 inches away over once more, then let it set for about 12hr, before handling and longer before you install. If that does not seem dark enough hit another heavy coat and that should be plenty! I have used this on two bikes now, a trailer, and my tacoma! GOOD STUFF!
