Let me see your tail section with lights
CM400 Tail End. Still working on cool ideas for brake light. Any suggestions? Mini blinkers look good and are very bright.
Got all the led's working/blinking now. It took an EL-12 flasher relay from Napa and it works great now.
DBC said:
my 78' CB550. made the tail from a piece of steel and shaped it around a tail light from a Roadstar Warrior
Hell yeah. Sick bike man. You got a build thread on here?
I frenched in my tail light too with a side marker, i only paid $5.50 for it. but it was a single filament bulb and housing that i didnt find out till after i frenched and mounted.... durrr stoner moment lol. but luckily the stock tail light housing and bulb fit.
thanks man! yep, check my sig. I also have another project in the works that I think you guys are really going to dig the tail on. It will be done sometime in august.
Got the new taillight hooked up. The pic is just the photoshop version but it looks exactly like the pic and I am happy with the look. Honda CM400.
Since I finally got my brake and turn signals finalized, I figured I'd throw my hat.....er.....ass......into the ring:
Used a universal LED third brake light assembly for the brake/running lights and a set of flushmount side markers for the rear turns. Since the LED bar was a 2-wire hook-up, I had to solder up a dimmer circuit into a small project box, so that when they are feeding off the run circuit, they are dimmer, and get brighter when you hit the brakes. The hardest part about the whole thing was finding an LED bar that matched the dimensions I needed, in order to fill the space, properly.
Wingspan said:
I used a round LED from Custom Dynamics and a pair of small LED blinkers I found on Ebay:
How did you get the flange to sit flush with the curve of the bump? I'm about to put one in, but I'm afraid it'll stick out like a sore thumb...
The Roc City Cafe tail I used is quite thick ~1/4. I was able to remove enough material to make the bezel sit flat. Just took a few minutes with a Dremel tool and a router bit.
Re: Re: Let me see your tail section with lights
Nice! Thanks for the profile :) i'm afraid to cut into mine but have to :3
Sent from my DROID2 using Tapatalk
hi, first post...now that I'm slowly getting this thing dun....
First Klass Glass champion fender/seat with a Kawi integrated light...
Anybody seen those tail lights that fit straight into the frame, much like bar end signals? I came across them somewhere online and can't find them again. They could work well where I've chopped my subframe short, and them stuff them in there...
