Let the fun begin - CLstyle
some pics of removing the cables from my carbs
hope that helps
mate, you rule. yeah mine must be stuck with crap. ill let you know when i get them apart. i cant thank you enough.
cheers
you guys who have the 350 are they big enought to haul you around. I am looking for something to have fun on and I might have a good lead on a 350.
some progress
ok. i know i wanted to try to start this thing by summer, but i had to get the daily rider running properly. i have the cb360 sorted out and it is now summer. if i could get the oil filter out to clean it, i would try starting the cl175. i have been through the carbs and cleaned the wiring. i spent sunday making the exhaust look better.
from this
to this
and these
to these
im about to just put clean oil in so i can try and start it without cleaning the filter.
oh and i tracked down some front forks. that was difficult because the k7 is different then the earlier models
ericngsta said:
how did you clean those exhuast? They look REALLY good from before.
oh yeah i forgot that part. i started with coca-cola and aluminum foil and then went over it with metal polish. the coke and aluminum worked really well. the smaller parts i put in some ZEP Rust Remover for a few hours. then metal polish to seal them up. or atleast make me feel like they are sealed up.
Nice...
Imagine what coke does to your guts?? Doesn't stop me drinking it though!!
Did you get a set of stock forks? Are they 31mm like the CB? What bars are you going to use? Twenty questions or what?
How bout a pic of the 360 now its sorted?
i have not had coke or soda for about 14 years now.
more photos once i make some progress. yes the forks are 31mm. i thought about making a steering head that would fit the frame but allow for more standard 33mm forks, but i found some decent 31s. my tank is rusted and has no cap. i cleaned out my cl350 tank thinking i would just throw it on for now, but it would take some modification. this week i am getting a gas cap for the CL175 and new bars for the CB360. ill post pics of the 360 once i get new bars on it. it is staying stock-ish.
next steps for this 175 are oil filter cleaning (how did you get yours out?) and putting the front end together , clean tank, build seat, ride, maybe rear sets.
hotfunk67 said:
never tried
im in the same boat with my 200. not really sure either. i guess next oil change ill look more into it.
PS: if any of you guys with the CL175's have an extra LEFT side cover laying around let me know, ill gladly buy it off you... even if you don't have an extra maybe you could take some pictures and measurements of the tabs on the back. im trying to see if it will work on my CB200 since CL200's are hard to come by.
