Liam's ACE 125
Wow ! - yes, it looks very good indeed ... the stainless finish really stands out against the black & silver ...
Did you have to cut the header pipe to suit the length / position of the silencer? How about space for the rear brake pedal when pressed?
And ... most of all, how does it sound ?!! Love to know your opinion on ride differences 'before' and 'after' the EGR, exhaust and re-jetting.
Haz
Part 2 of the fork pre load and oil change.
First built myself a custom ACE stand. With a hole cut into it of the sump plug so it sits nice and square.
One fork leg out. One to go.
One thing just leads to another! I should have stripped it down and put it back together how I wanted it.
God it looks like a construction site ! - but the end results has got to be worth it ! ... thanks for all the updates, it's very interesting to follow your progress, Liam. Don't think I'll be attempting anything that drastic !!
Haz
A little bit of tidying.
Sticky old insulation tape.
Two minates later all tidy and clean heat shrink.
And the forks are back on with the modded crown.
Haz
The header just slips inside the silencer as it only has a baffle in the back half so I'm going to leave the header full length as I believe this helps these little motors.
There should be enough clearance bit I will see when I get it fitted up properly this coming week.
Can't wait to get it started and have a listen, probably won't happen til next weekend now.
Hazza00 said:
Hey Liam .. the clipon's look very chunky, nice job !
How did the replacement exhaust go? I ended up ordering this silencer from 00racing, hope it's a little more 'muffled' like in the youtube vids ... their website says "sounds great like a 600cc bike" ... hmmm, not holding my breath but crossing my fingers!! hehe ...
http://www.ooracing.com/store/index.php?act=viewProd&productId=4318
Haz
I should be able to get it started this weekend, I will get a vid of it running and post it up.
Can't wait to get it going again.
New front tyre on, back tyre half off turns out a little WD40 on the beading and the tyre pops straight off, only took 20 mins of struggle to figure that out!
Rear tyre, shoes on Chain and brake adjusted. Wheel true and tight.
And obviously the best thing the new stainless clip.
Re: 回覆: Liam's ACE 125
josephau said:
wow....its gonna to be a brand new bike !
Sent from my IM-A880S using Tapatalk
Cheers mate I'm aiming for better than new.
Got some super secret bits to pick up this afternoon!
回覆: Liam's ACE 125
do u have the rear EBC brake shoe part number which i might replace mine some time later.
Brake pad No. http://www.dotheton.com/forum/index.php?topic=55496.0
Still so much to get done, all I want to do is go for a ride!
回覆: Liam's ACE 125
im sure you wont regret the time u spend on it!
... hey Liam, that header looks just fine as it is, without a silencer !! ... start her up with just that, you'll soon get to know your neighbours !! hehe
I'm going to pick my header up tonight & other bits from 00racing that's arrived, so got some work to do in the weekend also !
Haz
