Lighting problem
Bobby4Prezz
no matter how i hook these lights up http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=280413115948&viewitem=&sspagename=STRK%3AMEWNX%3AIT they won't blink, they stay lit, until i hit the turn switch and they turn out. please help!
Need more info. What bike is this? If you dont have both front and rear lights on and connected properly the flasher module (relay) won't make them blink.
Tony
its a hondamatic 400a, i took out the headlight to look at the wiring, if i hookup old lights they work, but when i pug in the new lights, the same as the old or any other way it just stays lit (running light) or goes out when i hit the turn signal. or it will other way around, no running light but when i turn on blinker the light comes on. but the old ones work fine, just trying to update the look.
Take the bulbs out of the old signals and put em' in the new ones. Bet they are different (and the wrong style).
they are way to big to fit. I had to ad a 3rd wire to each light, now when i turn the signals on the front and back lights on the correct side light up and the other goes dark. or if i switch the wiring i can get the right blinker and both tail lights to blink... im stumped.
tjjkc said:
Do you have the new lights well grounded...........
theres only 2 wires coming off the lights, a gray and a black, i figured it might of been the ground, so i added a 3rd, which works except it makes both rear lights blink, no mater which way the switch goes almost like a kill switch.
Hello! Alright, here's what you have to do:
First of all, you will not have running lights, only blinkers. Since they don't come with a third "filament" and wire for that. So, wire the only power wire into your original blinker wire on the bike. Obviously wire the grounds into the old ones as well. Now, they should stay lit and not blink when you hit the blinker. If this is the case, you need to replace your flasher relay with an electronic one. You can pick one up at any parts store. They have 2 and 3 pronged ones. My CB550 had the two prong, but you need to check yours. They are like 5 bucks. The problem is that the old mechanical ones worked off of resistance. When you switch to LED turn signals, they have a much lower resistance, so it never causes the relay to "flash."
Anyways, I hope that helps. That's what I went through when I got mine as well. Fairly common problem and luckily an extremely cheap and easy solution. Again, if you still have problems after all of that, ensure all your connections are clean and tight. A bad connection between the front and rear lights may give you some problems as well.
When you say extra wire do you mean an extra earth wire? That may be the issue as (and i may be wrong on this, forgive me) 12 volt switching is usually done on the earth wire. If you've wired an extra earth then it won't be earthing through the switch. Wire it up the same as stock, only two wires are needed.
ok here we go, i just took some pictures so maybe you guys can help me figure this out..
http://img406.imageshack.us/img406
/3499/picture36w.png
http://www.picgames.com/forum/myspace-image-help.php This was the blinkers i took off, they have somekind of nut that "grounds out?"
http://www.picgames.com/forum/myspace-image-help.php This is the new light installed, note it only has 2 wires, without that "grounding plate?"
http://www.picgames.com/forum/myspace-image-help.php because it didnt have that wire that was on the other light i added this green wire to the bottom of the light, but when i hook it all up and put the green wire where it came out on the old light it makes a "ticking" noise and the lights go dim. I blew my main fuse once already trying that. these arent LED lights, they are single filiment blubs, and the old ones were double filiment. Hopefully this helps, and someone can help me
Have you hooked up the two wires to the original two connections on the bike, without your mod and without worrying about the grounding through that bolt? I didn't think any indicators grounded through the body via the bolt anyway. They're switched by the relay on the -ive so by grounding it you're gonna confuse the relay and blow fuses.
i've tried just using the 2 wires and it just lights up, i've run it s few different ways and gotten the right side to blink. but both rear lights blink, then when you flip the switch it acts as a kill switch doesnt matter which side the lights are flipped 2. it lights up the same. If it didnt need the ground y would it of been there from stock?
the way i have it wired right now, is the closest its been to being right, when theres no blinker on they running lights are on, when i flip the switch it turns the opisite side light off, and the correct light on the tail on. but no blinky
Dude you have no running lights you have a single filament bulb you only have turn signals. The reason they are not working is because they are back feeding when you hit the turn signals. Disconnect the running lights. Find the wire for your turn signal the one that flashes and hook it up. then ground them out. voila turn signal but no running lights. The black wire on your new ones is the ground and the green one is the power. hope this helps I'm pretty sure it will.
Yeah I just reread this thread I'm right. By getting the single filament bulbs you gave up the running lights. Think about it. How is the bulb going to flash and stay lit for your running lights at the same time.
This thread is confusing me.....
I believe Thompson is right though. Except maybe about the green wire. Didn't you say you added a wire to the blinkers? If you did, get rid of it, it's not helping. If they are single filament bulbs then you can't use them as running lights - only turn signals. And if they are rated for a higher wattage than the original bulbs you will have to get an electronic turn signal relay.
Without checking the ebay post, I believe the 2 wires were gray and black? Make sure that they are wired correctly and not switched.
PROBLEM SLOVED! Lighting problem
thanks everyone for your help on this, but Staffy was right all i needed was a new electronic signal can $12, and now it works like new, running lights work and the blinkers. so thanks to everyone that helped out! now on to my next lighting project!
Thanks Bobby but i can't claim it. Highwayhigh had suggested it on the first page. Glad i could help you through it though and that you got it all sorted out champ.
Lighting Problem #2
so finally heres the lights that gave me such a hard time, installed http://www.picgames.com/forum/myspace-image-help.php and after that i installed these bullets on the rear, http://www.picgames.com/forum/myspace-image-help.php i updated them with a double filliment so they can be both turn and brake lights, still wiring up the brake light for some reason it stays lit all the time even when brake is applied, plugged in the old brake light and same thing, could it be a brake light switch or something?
