I had the same turn signal problems on my sr500..
here's what I did:
well... here's what I did:.
Im assuming that the aftermarket turn signals are tested and all work independently from the wiring harness
1. Check for power going into the flasher relay
- power... then goto step 2
- no power... then look into why no there is no power into the relay. trace back wire and check fuse.
2. Check for power going out of the relay into the handle bar.
- power... then goto step 3
- no power... then replace relay. If you are running with no indicator lights use an electronic two prong relay
3. Check for power at the handlebar switch, (power going into the switch)
- power... then goto step 4
- No power... then there is a break in the wire somewhere in the harness. You will have to look for a break in the harness somewhere...
4. Check for power going OUT of the handlebar switch when left or right indicator is on
- power... then got step 5
- no power... then problem is in the switch.. Take it apart and clean or re soder the wires inside
5. Check for power at the turn lights themselves. Remove the bulbs and test the connection in the housing
- power... then faulty bulb
- no power... perhaps bad ground... goto step 6
6. check for power in the wire, going into the bulb housing
- power... then faulty housing or sodering at the connection between wire & housing.
- no power... Crack open a beer and call it a night... try again tomorrow...
I was lucky.. I found the problem at step 4. I didnt have to tear into the harness itself.
Past step 6, wouldnt know what else to suggest... perhaps some of the electrical gurus might have some additional ideas that I may have missed...
