Lithium charging system?
Jramos13
I will be using a battery tender lithium battery 12v 10-14amps, the battery sady that the max charge rate is 10a, butmy xs500 charge rate is like 12-15a i think, so would i need another voltage refulator for just charging the battery? Or is it ok to use it like that?
This is the battery
Jramos13 said:
This is the battery
10 AMPS. max charge rate to the battery.
Volts and amps are two different things. You can have a 1 volt power supply that has 10 amps, and you can have a 1000 volt supply that has 10 amps. There is no correlation. You want to see 14 volts charging somewhere around 2000-2500 RPM. if you have that and no parasitic draw your fine.
I still suggest anyone who leaves a bike for more than a few days that they install a disconnect or manually disconnect the ground from the battery.
I got mixed up on my original post, i meant 14-15a instead of volt, factory it charges at 14-15a
