"Locking sealant" type?
Finnigan
Over 1,000 Posts
Putting my front fork tubes back together after replacing seals and fluid, the owner's manual calls for me to put locking sealant on the socket bolts, im assuming this is referring to Loctite of some kind. Does anyone know what type would be good to use?
Thanks
if you are referring to the cap head bolt that locates the damper rod in the bottom of the slider, then yes, it needs loctitie or even a thin smear of 3 bond will work.
The top screw and drain bolt don't need sealer/loctite as Swivel mentioned.
Just use Blue not Red Loctite. Don't need the 'permanent' stuff. These are critical bolts (the ones that lock your dampening rod to the fork lowers) as without them, your bottom end could slide right off the forks. But, the bolts would have to back out entirely and if I'm not mistaken, the axle would prevent them from backing out to the point of actually releasing the mechanism. Still need Loctite of course.
In my Clymer's manual there are appears to also be a torque spec for the "front fork bolt". Is this the same as the damper rod bolt?
Just wondering if I need to torque it or just use the loc-tite blue.
Thanks
