Long time lurker first time poster
Lumo423
Hey Lumo here as the subject says long time lurker, first time poster. I've got a 1981 CB650C almost completely stock, I have pods (its the way I bought it). It's currently in the shop to figure out why it won't go past 70mph, I recently replaced the top end gaskets and resolved an oil leak (leaked like a sophomore at senior prom) and had a carb sync done... afterwards no 103mph...
any suggestions?
Need a bit more info...
Compression test?
Carbs cleaned (correctly)?
Timing set properly?
Etc...
Then perhaps we can be a bit more help.
Welcome to DTT. Good luck with the 650.
Timing is set properly, compression is where it's supposed to be, but I haven't checked to see if the carbs are properly cleaned properly by the shop. I'm gonna go through carbs clean them up. It was running fine before I took it to the shop, seems to be running lean now.
I know CB650s are the red headed stepchild of the CB community and parts are hard to find as well. I do love the bike though. :)
Cleaned out the carbs this afternoon, seems that when the mechanic worked on the carbs he put 145 jets... The bike originally had 120 jets (stock jets are 92). Bike is back to normal and did a ton to celebrate!
