longer forks weight placement?
legendary_rider
Jump in with both feet.
Putting 750 forks on my 350. I was going to chop them down to same length as the 350's but then started to wonder....would longer forks be better off the line cause it would change the front/rear weight ratio and lengthen the bike?
Maybe some engineering guys could help me out? I'm going to be doing vintage road racing with it. Thanks
It'll affect handling way more than it will affect your acceleration. The only reason to move more weight to the rear (for acceleration) would be if you're having trouble with grip and I suspect that won't be an issue for your build.
My advice would be to try to keep the front at the same height as stock, for now. Try not to make any sweeping changes to handling until after you have things put together and you have a feel for your "new" engine. You always run the risk of spending money doing something and then spending it again to undo it. Better to just spend the money once, after you know what you're trying to accomplish. Replacing components on a whim is a very easy trap to fall into. If you're replacing something, know why you're doing it and what problems it will not only solve, but what new problems it will create. And trust me, nearly anything you replace will cause new problems.
You would have been better off with 500 or 550 forks.
The 750 is a heavy bike compared to a modified 350, the springs will probably be too hard.
Cutting them will make the spring rate increase (less working coils)
You could try 500 or 550 springs in 750 tubes (I know they fit and are shorter than 750 springs)
legendary_rider said:
Thanks for the advice. I wish you were around to chime in when a guys post on here recommended 78 or 79 cb750 front forks as replacement. He should remove it to stop steering people wrong.
Link to this post?
No offence taken. Doesnt really matter to me in the long run, just curious. The 750 forks will work just fine. Just rebuild them to suit your application. Not a big deal.
Are you going to race on circuits or straights? surely longer forks will affect cornering ability.
