Lossa Engineering 2" tail light
AndrewWard
Hello,
I have run into a little problem with my build, I am rebuilding my KZ650 into a cafe and ordered a tail light from Lossa, the problem is that it did not come with the wiring harness or instructions. I have tried to call them and email them with no response. The bike has three wires and the tail light has two inputs, I found at a local NAPA a marker light that is almost identical and the wiring harness fits, but is still only two wire, do I need to splice a third wire into it? But how do I make it always on when the bike is running and brighter when I hit the brakes?
Any help would be greatly appreciated
Andrew
A picture might help....
First, is it a brake and taillight. Some are only Taillight.
If so, the usual setup for a Brake and tail light is one wire is 12V+ for the tailight, one wire is 12V+ for the brake light, and the mounting screw/bolt is ground.
Do you have a link for what you bought?
http://www.lossaengineering.com/shop/lossa-l-e-d-tail-light/
It is a brake and tail light combo. I never received a wiring harness when it was sent to me, the light mounts without a screw or bolt, it uses a rubber grommet that surrounds the light to hold it in place. The back of the light has two inputs, and I found a harness for a trailer marker light that connects but still only has two wires, I was thinking I could splice a third wire onto it but was thinking that it would need to have a resistor on the wire for the constant on and no resistor on the wire from the brakes so that it would be brighter when I hit the brakes. Am I looking at this correctly, does that makes sense?
Instructions on the site say there are three wires....If not, call them and ask for the correct light...
Pic of instructions on the link you sent:
That has been my problem, I have been calling them and leaving messages, as well I have emailed them, the response I received from them was to connect the tail light to the wiring harness and if I had lost the instructions to go on the site and get them there, I have still heard nothing back since I had informed them that they only sent the light with no harness, no instructions and no receipt. I am just getting frustrated, it says in the instructions online that the wiring harness has three wires but the back side of the light has only two female pins, I explained that to them when I contacted them and the reply was that yes the light has two pins and the harness has three wires and to use the wiring harness (which was not provided)
Andrew,
This light is simply a DOT truck trailer light and grommet. The wiring harness you found is modified via Lossa to include a third power input line. this will achieve a similar effect for $8.50 via your local Pilot truck stop and radio shack. (if I am wrong I am willing to recant).
I used a similar setup on my GS450 at first. The factory wire in the harness is a power and a ground. By adding a resistor to this line you are dimming your running light function of your tail light. If you add a third wire soldered in closer to the taillight )than your resistor) for you brake switch , then when your brake is applied the tail light gets brighter.
Several other member have done a similar mod with success as well.
Gary
It may be designed to ground using the light housing/mount to the frame. What happens when you connect the light to a battery?
Unless it's missing a wire, it has to be a self grounding light with one lead for a running light and the other lead for tbe 2nd filament for the brake light.
