Lower fork bolt help
cafePete
Coast to Coast
DTT BOTM WINNER
Hope someone can help, today atempted to replace the fork seals(cb360), first fork done no problems.
Second fork I can't seem to remove the lower fork bolt, it just keeps spining :-\.
Has anyone had this problem? if so any tips.
Thanks
You can try putting the springs back in and the end cap....that puts some pressure in the end "nut" and holds it from spinning ..
Or you can try an old broom handle ,and jam it in the to the "Nut"
orrrrrrrrr try an impact driver,
pull spring out and everything you can and then use a broom stick down inside the fork tube with pressure while you turn the bolt out....
On my XS650 I had to use a looooooong socket extender to reach down into the fork tube to secure the top of the contraption in there that the bolt you're working on threads into.
On your bike I'm not sure what size socket you'll need - should be in the service manual how to do this. You'll want the socket in place to tighten things up again when you're done.
Or as mentioned, put the spring etc. back in the top and then loosen the bolt.
on his the bolt screws into a piston which has a smaller spring on it.....theres no nut or anything you just need to hold it with a broom stick or something like that
i used an impact and it came right out. of course i cant remember if i had the spring and top on or not. so im not much help
dcmspikes said:
so did you get it with or without the spring and end cap?
Had to put the spring and cap back on, then I fliped the fork upside down, put some weight on it and it came right out.
Also had to do the same tighten the bolt up.
Thanks
Thanks
thats the way to do it...
springs must be in there for proper dissasembly; keep everything together, lean on the fork to get the spring compressed a bit, unscrew and voila.
i have preload adjusters on my forks so i have to disassemble them before popping that bottom bolt out thats why i prefer using a broo, and who wants their fork caps scratched up anyways?
