Luggage
HK_Sailor
Hi guys, fairly new here :)
So I have decided I need to be able to carry more luggage than what I can fit in my back pack. Not much more, but more none the less. I think many of you can agree with me that those big black plastic helmet boxes are the ugliest things every to be invented, however they work really really well. My idea is to whip together a can or drum shaped thing about 400mm long by 250-300 mm diameter to be fitted onto the back of my '99 Honda Steed 400 after I've re-built the back end. (I find the stock fender ugly and the seat too chunky).
My plan is to use 2mm mild steel sheet with a sheet roller to create the shape I want. The can/drum will open via a piano hinge or similar hinge and close with a clasp on the other side of the can/drum.
I've attached a drawing, hope you can see it... and I hope its not too big but yea this is my idea.
Tell me what you guys think?
I think it's gonna weigh more than what you put in it! ;)
For trips I use saddlebags (old plastic Krausers on my BMW) and a duffle bag on the back end of the seat held down with a bungee net.
I'd make yourself a nice platform that you can remove, and use it as a place to tie down a bag to. This way you can easily pick up the bag and take it in with you when you get where you're going.
Simpler is better :)
