Make Harley build a cafe.
Yup, I own 1.5 of them. Haha... Though when I get within 10ft of anything that has "ride to live" printed/stitched on it my skin starts to crawl.
I have to add my 2 cent. Going thru all the post on this fourm I've notice a lot of guys own a Harley, it sits next to there jap or britt bike. Which leads me to belive they have the same motto I do
(IT DOESEN'T MATTER WHAT YOU RIDE, JUST RIDE).
I have ownd 3 of them. started with 99 sporty 883 owned it till I could afford my 03 FX springer , Love it. 25,000 miles, never broke down, never a oil leak. With all the flack Harley gets you could not make me belive they are a bad bikes nor could you talk me in to selling mine. I think they got a bad wrap back when AMF owned Harley.
Up untill I was 35 years old you could not have got me to buy Harley so I do belive it comes with age. Having grown up on jap bikes and having all the makes and from 50cc to 1200cc. I never had a bad one in the bunch and some of those were some real POS. And now I'm lovin my Suki build. So ride whats have, ride what you like, F@ck it, lets ride.
... or their German bike...
My wife wanted to ride the Harley to work today. First time. She loves it so much I'm not sure if I own a Harley anymore. (I'm guessing no.)
Damn it matty...everytime I see your BMW I get light headed. It's so beautiful ;D Congrats again on your BOTM win.
Off topic I know, but what can I say
The HD engine is based off a radial engine... What would be "so" hard to make one in to a HO/ Boxer style like the BMW?
Short of the case and cam shaft... AFIK, It shouldn't be "that" hard to mill a case...
Well... Thats out of left field. Haha. Why would you want to? A boxer engine and a 45deg v-twin have different characteristics, performance wise. Also, the internal workings of both configurations are waaaaayyyyy different. Its not just a matter of new cases. And most HDs dont have cams. Theyre pushrod motors.
Well, those pushrods are actuated by the cams but...not overhead-cams....
Yes, you could build a flat HD motor with some heavy fab work. Not sure what it'd buy you other than having a cool weirdo engine (that's reason enough most of the time!).
All I'm interested in is the jugs and heads on a flatty. It would be the same as an airplane engine... The case in its simplest could be a box with some bearings for the crank. The stock cam could work too... Of course it would change the orientation of the crank shaft but...
Think about it. The cam has lobes timed 45° apart for cylinders at 45°. Move the cylinders to 180°, and one pair of lobes would have to be relocated.
Guys.. I really think you're going about this the wrong way.. This is clearly the answer you seek.
"Life finds a way..." - Jeff Goldblum
Clearley I'm out of my feild of expertese, I thought it was one lobe controlled both intake and another lobe controlled both exhaust so regardless of how many and where they cylinders/ heard are the valves would work accordingley.
Thanks.
Ya... I was lacking in my explination of my confusion. Haha. Anyhow, machining a case to run HD jugs horizontally opposed could be done, sure. The big issue is how to transfer that motion to a transmission and chain drive in a bike.
Thanks.
Perhaps you're confusing the single pin crank with the camshaft. Both rods are connected to the same crank pin.
Now (showing my own lack of HD experience) couldn't one 'reclock' a twin cam? If i understand correctly that particular motor has a cam for each cylinder and my pre-coffee brain says that one should be able to machine that opposed cyl. case and simply retime each cam 45* farther out in the cycle relative to it's original 45* nature, yielding a 180* setup.
*should work*
I found this one on another site, don't have a clue who built it. I thought it had a lot of style and was a unique build considering most gravitate to hardtails and springers.
Rider
